Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I am trying to get more oil on the bar and chain, does the wild thing have an oil adjustor and if so where?
  • 56 Answers
I have the same one , no it doesn't have one but use a thinner oil and it will do the job perfectly, it doesn't matter what kind of oil just thinner than gear oil.
Posted on Jan 05, 2009
Have a poulan wild thing and the oil bar compartment has gas in it
I would drain the oil and gas or whatever is in it. I would also drain the 2 cycle mix from the gas tank and start with a fresh gas and oil mix and fresh bar oil. The mix for the Poulan Wildthing is a 40:1 mix.
You are definitely going to smell gas when using any chain saw.
Oct 28, 2014 | Poulan 18" Wild Thing Chainsaw
Chainsaw Bar oiler empties as soon as filled
You should be using bar oil. It clings better to the chain and bar providing better lubrication.
Apr 13, 2014 | Echo Garden
Poulan Wild Thing bar oiler adjustment
there is no adjustment for the oil flow i find the screws that hold the pump on loosen up and then leak oil
Jun 09, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What kind of bar oil goes for poulan wild thing
Hi, any brand of chain n bar oil is fine, regards Phil.
Jun 02, 2012 | Poulan Wild Thing Chainsaw Oil Line
Wild thing saw brand new used once, over heating, not wanting to cut, why?
If there is no oil getting to the chain, you will have metal to metal contact between the chain and the bar with no oil film, the chain will look dry and be covered in baked on resin from the heat, make sure you have adiquate chain oil in the oil chamber, this chamber is seperate to the fuel chamber, it should be filled with a non fling chain oil.
Aug 28, 2011 | Poulan P4018WT Wild Thing 18Inch 40cc...
Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin: I own a Wild Thing 18". I don't believe the auto o...
Remove the bar and chain. Start the engine and observe the side of the engine where the bar fits to it. The oil port there should ooze oil out when the engine runs fairly fast. If nothing, then investigate the filter within the oil tank for plugging, the oil line from the tank to the pump for any damage or decay, and the oil pump itself. The pump should discharge directly to the port that the bar receives. If oil did ooze out of the port on the first test, then clean the oil passages in the bar end--two small channels that run from each large hole out to the chain groove on each side. Clean the entire chain groove. Check the sprocket on the other end for fairly free turning--oil it's bearing. Examine the chain carefully--if it got so hot that it turned the teeth blue--replace the chain, it has lost it's tempering. Assemble bar and chain--adjust the chain so that the lower side doesn't droop from the bar, and you can turn the chain by hand. The teeth cut toward you on the bottom run. If the old chain is being reused, sharpen the chain carefully so that it cuts quickly without undue effort on your or the engine's part. Hope this helps!
May 17, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a poulan wild thing 18" bar and I have had a problem with the bars wearing out quickly. I use regular poulan bar and chain oil. Did this saw have a specific problem with the oiling system?
If the oil level in the chain oil tank goes down normally then you may be running the chain too tight. Also make sure the oil ports in the bar are clear so the oil can get to the chain. hope this helps you
Nov 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Oil comes out the cover and doesn t oil bar and chain
remove the bar and clear out the oil passage holes in the bar and if you have oil coming out of the oil port in the saw then you should be okay...hope this helps...
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Insufficient chain oiling
Sorry to tell you this but you need a new OIL PUMP but it's not a difficult thing to replace.
On the main shaft of the crank shaft under the centrifugal clutch is a spiral wound wire that matches a plastic part that is the oil pump. You can get the part from Poulan parts and it will take about 15 minutes to fix the first time eight minutes the second time.
Glad to be of assistance.
Oct 09, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
111 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
