I can't figure out how to connect my blu ray player to my Olevia 542 tv
Can't figure outhow to hook up the blu ray player to the tv
  • Carmela Russo Nov 05, 2012
    thank you so much. It was so darn easy, Any suggestions as to how I can connect my wi fi to it? every time I hkey in the #'s it says it's invalid???
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Whatever the player uses --Component (blue-green-red) or composite or HDMI for output connect to the correct and identical input on the rear of the set----switch to that input and see what you have.
Posted on Nov 04, 2012
  • 362 Answers
SOURCE: trouble hooking up sony components..Bravia, Home theatre, blu-ray
Got your post, I will work with the model #s. Get back with you soon. Also a tip for now: HDMI carries true digital video and audio so you may not need the optic cables.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 30, 2009
  • 19 Answers
SOURCE: 42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Posted on Feb 21, 2009
SOURCE: When trying to connect my 4695D to a new Sony Blu
The problem has been solved. A previous post to this site was having a similar problem hooking up a Playstation Blu Ray player to the same TV.
A solution was posted to that problem and I followed the same instructions.
It has to do with the set up porgram on the Blu Ray component. You need to select Settings then 108024Bit needs to be set to off.
Posted on Dec 29, 2009
omaharox
  • 166 Answers
SOURCE: Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
Posted on Jan 18, 2010
SOURCE: Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Posted on Apr 26, 2010
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
Sep 02, 2015 | Emerson Televison & Video
Hook-up
Harold,
Please provide the manufacturer's name and model numbers for the DVD / Blu Ray Player *and* TV. Without this info, no one will know what connections are available on either.
Jul 18, 2013 | Televison & Video
ProScan TV - Movies playing on Blu Ray via ProScan TV are all in black & white. I am certain I have a connection wrong but can't figure out which one - the "names" of connections on ProScan a
why do not you try totalmedia? I have used it for almost 2 years and never had any problem. it plays blu ray on pc smoothly. when i bought it, to my surprise, it can change region code, thus i'm never worried about relaxing myself when on business. It's an easy to use and professional blu ray player software for windows; including Windows 8. of course, it fully integrates with Windows Media Center too. beyond your surprise, it's also a 3d video player.
Feb 16, 2013 | Video Game Consoles & Games
Hookup Blu ray player to Onkyo pre-amp for speakers
If you have audio out jacks from your tv, you would be better served hooking that up to the preamp. If you hook up the blu-ray player separately to both the tv and amp, the audio probably will not sync with the video correctly. The tv takes longer to decode the hdmi input and the audio will be ahead.
Jan 22, 2013 | Onkyo Audio Players & Recorders
I'm getting sound from my sharp tv when hook uo to my blu-ray player
If I understand when the blu-ray player is connected to the set you get the TV sound or what? If properly connected by way of a set of rear audio/video or component jacks to the same on the TV--you should if change the TV input to that location see the blu-ray and hear sound it sends out.
Component, composite, or what is the hook up between the two units?
Dec 05, 2012 | Sharp LC70LE640U 70-inch LED/ LCD TV
IS THERE A WAY TO HOOK ETHERNET TO A SHARP BR MODEL BD-HP20U
You can connect it by any way to your BDP. There are cables to connect in between. HDMI, S-Video & AV. After connecting these cables with your TV, select the appropriate selection to video by TV.
Jun 01, 2012 | Sharp AQUOS Blu-ray Disc Player
Receive an invalid format message from my Olevia 32 tv
You get invalid format, or format not support becuase the video resolution setting on your PC is too high for the monitor to display, you need to lower your PC video resolution to the native resolution of the TV to get the best picture. Look at the owner manual for your TV or search the web.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 11, 2010 | Olevia LT32HVM 32 in. LCD Television
Need code for included blu-ray universal to work with an Olevia TV
if Samsung never included the brand Olevia on there remote, then its not going to work because it was never design to work with that brand. The only way to get around that is to get a learning remote or universal remote that has olevia pre program into the remote.. Olevia did come out with some learning remotes that is able to learn from other remotes.. the model its called Olevia RC-LRN ..
This company called Amergence Technology sells the RC-LRN remote made by Olevia contact them at this toll free number 866-965-3842
Apr 19, 2009 | Samsung BD-P1500 Blu-Ray Player
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Mintek MDP-1070
A component lead comprises of 5 phono plugs 3 for pic red and white for sound. If your TV has progressive scan it must have an HDMI connection if so and the MDP also has one that is a better way to connect it.
Jan 17, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
