Question about RCA P52926 52" Rear Projection Television
Will not turn on
I have a 52 in rca when i plug it in i have no picture & it make a churping sound & latly it turns off on it's own about 3 or 4 times before it stays on
  • Anonymous Mar 22, 2008
    rca 52 inch tv will not stay on
I have mod #p60755at give to me, i pluged it in it made whisling noise! i tracked it down, it was the HV splitter modual located in front access pannel,took it out, found 2 pin holes and scorh marks. I then took a hot glue gun,patched & replaced. It worked fine 3 months then quit! I changed that part (HV is high voltage,be sure it unpluged !) I replced the part and it still does nothing ! Power light does nothing,Ibeleive the problem is simple, I havent figured it out yet! Any suggestions?
Posted on Mar 25, 2008
    Sergeant:
    Champion:
  • 375 Answers
This sound is the power supply trying to fire,leaky caps notholding proper b+ voltage.you can check the error codes once the set does fire to view the fault code and narrow it what section is possibly at fault.rca sets take three tries then you out feature. thats why when it does fire check the codes,get a service manual also to help you out.
Posted on Aug 22, 2007
I have the D52W23 RCA TV and it will turn on but no picture will come on the screen. when you turn it on it makes a churping noise every 2-5 seconds do you have any idea of what this could be?
You have may be two bad eletrolytic caps and a high voltage safety cap that are bad. And maybe a bad flyback. This is the common problem for this TV. Sorry!!!
Mar 01, 2010 | RCA D52W23 52" HDTV CRT TV
Rca hd52w59 chirping sound and light 3 times no picture
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
Sep 17, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
No Picture
where can i buy Deflection board for RCA D52W20
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA-Churping Noise
it needs horizontal supply repaired and all will be well....
May 28, 2008 | RCA P56923BL 56" Rear Projection...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52754AT 52 in. No Picture No Sound
Sounds like the flyback failed,or a loose connt. on the high voltage area of the main board.
Jan 26, 2008 | RCA P52830BL 52" Rear Projection...
POWER PROBLEMS????????
If the set trys to turn on and makes noise three times then you hit the switch again and it will try to come on again churping three times , its a shorted horizontal output transistor and a bad flyback transformer. And Im sorry to tell you the transformer is no longer available according to RCA. Its a shame. I just threw out a 56" and a 32 " set that needed a flyback and could not get them.. Well good luck ps please rate this thread.
Oct 19, 2006 | RCA P52835LV 52 in. Rear Projection...
RCA P52926 52" Rear Projection Television Logo
79 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
