Question about Brother MFC 4820c All-In-One InkJet Printer
Have code 44 on screen and printer does not work
This started after i changed ink cartriges wich actually were not empty as was stated by machine. then i launched cleaning several times till printout was ok then i unpluged machine- had to move it and when i pluged it in it showed code 44.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
It says YELLOW empty. I changed the ink catridge with a new one. It won't work. says Machine Error 41. Do I need to change the Printer Head?
Posted on May 08, 2010
Ink cartrige does not move manualy on bar seemsto be froze
n my experience with these printers the carriage will only stop in the correct position, when you lift the lid, if there is an empty ink cartridge.
To force a change you need to go through the software on the PC.
Open the printer information, go to maintenance and select cartridge change and follow the on screen prompts.
Sep 29, 2016 | HP OfficeJet 7410 All-In-One InkJet...
Refill cartrige and printer says replace cartrige
A lot of printer manufactures place a small chip on the ink cartridge. Combined with the printer software it knows you re-filled the cartridge. This forces you to buy new ink. A work around that works with some printers. Keep you're old ink cartridges. Replace with new and when it empties replace with you're re-filled ink cartridge. Store you're old re-filled cartridges in a dry cool place when not in use. With HP printers users keep three cartridges.
Good luck.
Mike
Jan 14, 2010 | Lexmark Z2420 Printer
Epson stylus C86 will not print clearly in black
No doubt this is the result of some clogged print nozzles in the print head.
I have a C86 myself, and have ignored it for about 3 years. There were full cartridges in it, and now they are full of sludge instead of inks. The print head itself is probably full of solid ink (dyes, actually) too.
I love this inexpensive, easy-to-use printer. It is quick, quiet and inexpensive to run, and I have no desire to purchase a replacement.
Go to Ebay, look for the Dr.EpSun Majic Inkjet Flush Store (link should work)and locate the flush for this printer - with shipping about $25 US.
They claim a 100% Money-Back Guarantee if it doesn't work. I'm going to buy a kit myself right now, hope it works - I do miss this printer PLUS it works on MS VISTA with no added drivers!
Jun 06, 2009 | Epson Stylus C86 InkJet Printer
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
Printer does not recognize a full ink cartrige. Problem has responded to removing and then replacing the cartrige in the past, but that no longer works.
try to unplug your printer while it is in ON state ...it reset all your settings and after that it can recognizes your full cartridges..
May 17, 2009 | Canon Office Equipment & Supplies
Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Mar 15, 2009 | HP DeskJet 842c InkJet Printer
Ink cartriges not being recognized by printer
It is not uncommon for an Epson printer to fail to recognise Epson cartridges. It is either due to failing to go through the proper cartridge replacement cycle properly, or more seriously, due to a communication problem between the cartridge and the main board. To fix the first, simply go through the cartridge replacement cycle again (see your manual how to do this before the cartridges are empty). Simply take your new cartridges out when told to, and put them back in again when told to insert the "new" cartridges. If it's the second problem you need specialist help, or simply sell your printer on e-bay for what you can get.
Dec 17, 2008 | Epson Stylus Photo 830 InkJet Printer
My printer
sure....did you do a clean and alignment service after changing that black cartridge?
Aug 03, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Black ink problem
It could be also the clogging of nossels in color Balck?!
For this purpose you need a special Cleaning solution, wich you
put first in the balck cartrige and start 2x cleaning(when cleaning you should observe if the balck ink is realy transported through the tube !!).Then you shut down your printer for about 24 hours.After that you clean also
for 2x times and check after that the nossels printing test. If not all nossels are free you should repeat the hole thing once again....till the nossels are free.Another problem i observed at my printer is that at some CISS ore kompatible cartriges the rubber-sealing get used with the time and do not seal enough the
conection from cartrige to printer-head and they **** only air...
For this problem i sugested a solution ..see epson stylus 1400
i hope i could help
Apr 13, 2008 | Epson Stylus R265 InkJet Photo Printer
Printer cartrige question
Most hp printers print a alignment page when one of the cartridges is changed. If the other cartridge is empty, alignment fails, and printer will not work...
However for most printers is possible a procedure for bypassing a
alignment... if you tell me which printer you have !
Jan 12, 2008 | Office Equipment & Supplies
Brother MFC 4820c All-In-One InkJet Printer Logo
323 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
