Question about GE WSXH208A Front Load Washer
Front loading washing machine
My 6 year old front loading GE washing machine makes a thumping/rubbbing sound when turning. The drum appears to be mis-aligned with the drive system.It still turns and spins but the sound is constant. How does one re-align this.
  • Scott Randall May 20, 2007
    It also appears that something inside has broken. There is a large amount of whitish material that is all over the load of clothes that were being washed at the time.
    Problem Solver:
  • 11 Answers
You have a three armed support that holds the tub in place, this is not an easy fix, you would have to be very knowledgable of appliances and how to work on them to replace this. Basically one of your supports have either broken or the bolt has come lose. If you release the baffles inside the tub you should be able to see the mounting bolts for the support and you would be able to check the tightness of the bolts or whether or not the mount is broken. If the mount is broken in won't be cheap to fix. Hope this helps.
Posted on May 20, 2007
Front load washer has noise coming from tub when it moves sounds like someone knocking on the front door and then noise moves to a fant bell ringing sound it is a little over a year old tub appears to be...
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Thank You for using fixya
Sep 23, 2011 | GE WSXH208A Front Load Washer
I have an Electrolux Aqualux EW1200 i washing machine which is around 6 years old. The problem is that the drum no longer turns during the wash cycle. Instead it makes a slight grinding and banging...
6 years old - probably the wash tub bearings gone. Does the wash tub lift up and down from the front? sure sign bearings have gone. Would you drive a car at 70mph if the wheels were loose and floppy?
Not really a viable repair due to cost, and throwing good money after bad sort of situation, especially if your machine has a sealed wash tub which doesn't come apart.(welded Tub).
Cost of parts in this case would equal cost of new machine. Also, suspension, motor and heater will all be worn too. That's about the life span of machines these days I'm afraid!
Dec 09, 2017 | Electrolux EW1200i Front Load Washer /...
I have a GE front-loading washer. There is a horrible thumping noise as the drum turns. It is not constant - when I turn it by hand it seems to "thump" on every rotation of the drum. I ran it...
The thumping sound is a sure sign that the spider arms or the support arms that hold the wash drum are broken. It is a very expensive repair since you need to buy a replacement wash drum and spider arm assembly which almost cost as much as new washer. Get a few estimates before deciding whether to repair or replace the washer. Sorry.
Apr 23, 2011 | GE WSXH208A Front Load Washer
My GE GCVH6260FWW front load washer made a load snap while spinning. Repair man couldn't find anything. So we ran a load through and at the end of the wash cycle it started thumping and vibrating on high...
If the drum is also loose, it is dead. The plastic your are finding comes from a part inside. It will cost more (or close) to fix than to replace and you risk breaking other critical parts if you DYI.
Mar 01, 2011 | GE Energy Star WCVH6260F Front Load Washer
Front loader has gotten really really loud and shakes the whole floor when it spins properly. Today it left a lot of water in the clothes. It used to make a weird whining noise when it didn't spin out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | GE WBSR3140DW Top Load Washer
I have a white westinghouse model lt 350r 15 years old front loader. it just wont spin and i can't get it to drain. it looks like the tub inside has shifted, it sounded funny the last few times i used it....
To drain it, take a shop vac to the discharge hose to vacuum out the water. If the inner drum is sagging inside the outer drum or when you try to turn the inner drum and feel any kind of thumping noise, probally means that the spider support has failed. It can be expensive to repair.
Aug 27, 2010 | Tecnik TKL9260 Front Load Washer
Loud thumping noise when the drum starts to spin. The unit is level. It looks like the drum is not spinning balanced
see if you shake or tilt or move the inner tub
if you can you may have a groken spinner support
dont know hold old the machine is, but if its out of warrenty, it could be come very expensive repair
Oct 06, 2009 | GE WSXH208A Front Load Washer
I am considering purchasing a front load GE washing machine. I am curious if the inner drum and the outer drum are both metal? I am comparing the advantages of the GE front load with the Miele and the...
I can't speak for all, but my GE front loader has a stainless inner and a plastic outer tub. I don't know what the benefit of a all metal would be. The plastic outer tub seems to hold up fine, The only problems I have expereinced with the washer tubs were the bearing going bad after the seal failed, but its 10 years old. I consider that normal wear.
Jan 08, 2009 | Washing Machines
GE WSXH208A Front Load Washer Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
