Question about Tomtom Go 920T GPS Receiver
Increasing memory for the 920t
The unit has a port underneath . What kind and what size menory chip should I use ??
The manual should say what type of flash memory is supported, The actual memory size of the card should be suited to your needs i.e do you want to load  worldwide maps on etc
Posted on Jan 04, 2009
Coolpix p1 formatting problem on new memory disk.
There are 3 options, which come up to my mind :
1) Compatibility
The camera is containing a controller, able to communicate with a inserted memory-card. In some cases the size of the memory-card is not supported by this controller.
2) Protective mode
There's a small slide at the edge of this card. Maybe the slide is set to protect the contents of the memory card.
3) Pin-connections
Sometimes, you don't take care enough about the way you insert a memory card into the camera. Everything goes quick... If you inserted the card wrong, the pins at the menory card wont touch the internal pins in the socket of the camera.
4) Fake memory
There are some fake memory cards sold. This means, inside the card is a FLASH-memory chip and a tiny controller-chip. Some Chinese see it as a sport, to use for i.e. a 4 GB memory-card, replacing the outside cover with a text that states 32 GB. And likewise, they have to re-program the controller-chip, to think it has 32 GB FLASH-memory onboard. So, if you insert this card into a PC with Windows, Windows will show this card is 32 GB, while it is actually 4 GB. There are programs to test memory-cards for this type of fraud. However, most of the time, you can figure it out yourself, by checking the price you paid for this memory-card. If the price for this new card was extremely interesting (read : low priced), you probably burned your fingers.
5) Defective memory
The manufacturing process of memory-chips has it flaws. Luckily they use tests to check batches. If there's some malfunctioned detected, they throw it away. Unluckily, there are workers at those factories, who take these (partly) malfunctioning memory-cards back home and sell them at internet. Dealers just think about earning a quick buck and buyers face the results.
Oct 14, 2013 | Nikon COOLPIX Cameras
How do you install RAM?
Installing RAM on the keyboard is just like installing RAM in your typical computer. Unscrew the plates off the bottom of the keyboard and underneath you will find two parellel slots (usually beige colored) for the memory chips to go in. Simply place the memory chip in the slot. The memory chip has to to be a specific type of memory chip, does not take regular computer RAM. You can find specific kinds on sites such as ebay. Just type "Korg triton RAM" in the search bar.
Jul 17, 2012 | Korg TR76 76 Key Synthesizer Workstation
My del inspiron mini has no cd drive so how do i install new programs
Hi! Welcome to
You need to put your program on a flash drive or an external HDD and just plug in the to your usb port so you can install the programs yo like.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Dell Inspiron Mini 10 Notebook
How to increase memory hp presario c502
Go to and so a system scan to identify what kind of memory you currently have installed. You can purchase more memory directly from them or search for a better deal. Once you ahve the new chips, look underneath the laptop for a panel door with either a M at its corners or the memory icon. Unscrew the panel and proceed to remove and replace the old with the new memory. Be sure to unplug and power off the machine first of course. Good luck!
Mar 21, 2010 | Computers & Internet
Upgrading ram in a dell 5150 do I need to install 2 menory boards of the same size at the same time. I have two 256 mb and I am trying to install 1 512 mb to expand the menory to 1 gb It works for awhile...
you have 4 memory connectors. the maximum memory the computer supports is 4 GB. it is recomended that you install in pairs, for some reasons, but i have installed and i have seen it doesnot matter at all. you can go ahead and install the memory for whatever size on the computer. make sure the bus speed should be either 400 or 533 MHZ. and yoou never explained the error message. when you upgrade the ram you will get a message the system memory has changed press f1 to continue or f2 for setup just press f1. if the error message is in windows after you click on your name it has nothing to do with your memory. if its before that. than try to reseat the memory. installing memory in non pairs doesnot cause any problem most of the time. explain the error message only than i can guide you furthur.
Oct 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blue screen on start-up. Mobo SIS-741 Chipset SIS741GX Rev 03
This problem can be caused by several things. First, are the memory chips exactly identical (brand, type, size, etc.)? If not, that will definitely cause the problem. Second, how many memory slots are there? If you have four, check the manual and make sure you're putting the memory in the correct slots. Some Mobo's require that you put chips in slots A1 and B1 and not A1 and A2. Also, some Mobo's have DDR slots and DDR2 slots, so make sure you're putting the right kind of memory into the proper slots. Some people fudge the memory by putting 400 mhz memory into slower slots, and that works one chip at a time - but if you install a second, identical chip, the system will fail. If all else fails and you've met these conditions, check the type of memory to be sure of the proper fit (use manufacturer's recommended brands and numbers) or try a different chip in the second slot. One chip could be bad.
May 25, 2009 | SIS741GX-MN Motherboard
Toshiba A75-S211 memory
I'm showing a base memory on that unit of 256 so your max upgrade is 1gb to 1.2gb total.
1GB (1x1GB) Toshiba Notebook 2.5v PC2700 DDR333 SODIMM
Apr 14, 2009 | Toshiba Satellite A75-S211 Notebook
Tomtom Go 920T GPS Receiver Logo
83 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
