Question about Homelite Chainsaw Lx30 Bandit 180 192 200 Clutch
Fuel mix ratio for a homelite lx30 bandit - Homelite Chainsaw Lx30 Bandit 180 192 200 Clutch
  • 104 Answers
SOURCE: fuel ratio for homelite ut10829
the ratio should be 25 to 1 so 250 mls of oil for 1 litre of petrol
Posted on May 23, 2009
dontbother10
  • 2220 Answers
SOURCE: Have an older XL 16
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/87d4d17cf11a7c8b88256c280064b0b8?OpenDocument
XL-12 and 15 agree with your mixture, no 16 listed.
32:1 = 1 gallon of premium fuel to 4 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 19, 2010
dontbother10
  • 2220 Answers
SOURCE: I have a 1979 Homelite XL Chainsaw model # UT
32:1 according to this.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/57a3b86d6acae4e188256c260048b728?OpenDocument
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 14, 2010
dontbother10
  • 2220 Answers
SOURCE: oil mix ratio for homelite chainsaw
Current models recommend 50:1
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil. Once adjusted for this mix your saw will start easier, take longer to carbon foul, and is better for your grandchildren, regardless of what your manual says.
Lou
Posted on Apr 21, 2010
  • 4088 Answers
SOURCE: Fuel Ratio
40:1 is about right. Be sure to use modern synthetic oils made for saws and premix thoroughly before adding to the saw.
Posted on May 04, 2010
What is the gas /oil mix ratio for a homelite bandit lx 30 chainsaw
40:1...
(Remember, it's always better to he over than under...also, GET Alco no smoke...it's the best and cleanest oil mix out... it covers EVERY ratio as well, takes out the guesswork)
Oct 30, 2015 | Homelite Garden
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
I just purchase a homelite leafblower ut 09510 175mph, do i need to mix oil and gas for fuel?
Yes, you will need to mix up some fuel with two cycle oil. See your owners manual for the proper mix ratio. Keep this fuel in separate container from your lawn mower gas.
Sep 04, 2011 | Homelite Garden
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Homelite bandit bx 90, What is the fuel mixture?? Thanks
On the bandit, you are safe with a 40:1 ratio. In other words 8oz. of oil to 2.5 gallons of fuel.
Feb 12, 2011 | Homelite 'Yard Broom' Leaf Blower
Homelite ut 10695 spark plug gap, gas oil ratio?
Gap the plug at 0.020", and the fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil, fresh fuel, and mix in it's own container (don't make up more than a gallon at a time unless your business is sawing). Be sure to shake the container thoroughly each time just before adding fuel mix to the tank to prevent oil starvation. Hope this helps!
Nov 04, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
Homelite Chainsaw Lx30 Bandit 180 192 200 Clutch Logo
460 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
