Cannot run LA Noire on pc as fatal error DX92: SHADER MODEL 3.0 is required
4 Suggested Answers
  • 3 Answers
SOURCE: i just purchased need for
If you get this message it means the video card in the laptop is not compatible with the game, probably because it is too old. A shader is a set of software instructions used to calculate rendering effects on graphics hardware. Most modern graphics hardware is compatible with shader model 3.
Posted on Dec 26, 2010
  • 36 Answers
SOURCE: graphics card
Unfortunately, it sounds like you will need a new graphics card to run that game. Pixel shaders are built into the graphic card hardware and there is no way to download or install them. According to the games system requirements you need a 100% compatible Directx 9.0C card. If you post the make and model of your computer(or motherboard) I could recommend a card for you.
Posted on May 14, 2008
  • 111 Answers
SOURCE: when i try to play bully game on my PC i have
Im afraid this means your graphics card does not have pixel shader support- if you have a good processor speed download a pixel shader emulator otherwise you will need a new graphicscard that supports pixel shaders version 3
Posted on Apr 28, 2009
I Need To Get Shader Model 3.0 But Not Sure How Or Where To Get It.
Shader Model may be part of the video card. Hence, it does not support the game.
Jan 09, 2013 | Samsung R519-53S Notebook
When i play crysis 2 on my ps3 it goes well, but when i try to play la noire it shuts off and blinks red. whats the problem?
LA Noire has been causing PS3s to overheat. Make sure the PS3 is up to date, then maybe try putting in spot where it can get more air.
Jun 18, 2011 | Video Game Consoles & Games
I install juiced 2 but they told me about SHADER 3 GRAPHICS CARD
All latest PC games requires shader model 3 graphics card. Actually juiced 2 is a high graphic oriented game requiring shader model 3. So, you must upgrade the video memory by adding a latest graphics card with shader model 3.Graphic card like,
Nvidia 6600 and higher has shader model 3.0 ATI x1xxx or higher has shader model 3.0 some X800 were also shader model 3.0.
Before you buy any new graphic card you need to discover which card your motherboard supports.
Good luck!!!
Jun 09, 2011 | Video Game Consoles & Games
The machine GPU doesn't support shader model 3, which is required to run this game
I install Burnout paradise the ultimate box and got an error when try to play the game...
this machine gpu does not support shader model3 which is required to run this game.
I have Intel(R) G33/G31 Express Chipset Family, Integrated Graphic
Intel Processor Dual CPU e2200 @2.2GHz
Memory 1.99GB
What can i do to play this game
Mar 03, 2011 | Computers & Internet
I installed FIFA 11 on my PC and when I run it it comes up with a box say 'E001'.
Fifa 11 Demo PC E0001 Error Issue
Fifa 11 E0001 error happened to a PC with this or a similar Specs: Pentium dual core, integrated Intel graphic card, 1GB of RAM, 128 of vid RAM, 2.0 pixel shaders.
Fifa 11 Demo PC E0001 Error Issue Fix:
1. Fifa 11 requires a shader model 3 or better card. That is error E0001 will be fixed and you can play this game again.
So if you get an error message as E0001 while playing Fifa 11 on Windows 7 or other systems, you should first set to the shader model 3 of your card.
2. This E0001 error issue may also be related to the graphic card that you are using. Check the drivers you are using for the video card. Update and reinstall it if necessary.
3. Get the latest driver pack for the same and then process out for the implementation. You can download the current new AMD catalyst 10.9 graphics card driver here. Or NVIDIA ForceWare 260.63 driver if you are using a Nvidia card.
4. Change the resolution to have a try. Some users get the E0001 error fixed for Fifa 11 by trying the 1280x1024 resolution on his computer.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
Jan 11, 2011 | Video Game Consoles & Games
What does error 1203 mean on my lexmark A4270 when trying to receive a fax?
i think is code error for cartouche try this solution i hope to be helpful :
  1. Retirez les cartouches d'impression, puis fermez le couvercle du chariot des cartouches.
  2. Débranchez le cordon d'alimentation de la prise de courant.
  3. Rebranchez le cordon d'alimentation à la prise de courant.
  4. Si le voyant button_power_0.jpg n'est pas activé, appuyez sur button_power_0.jpg.
  5. Réinsérez les cartouches.
Si l'erreur ne réapparaît pas, le problème a été corrigé.
Si le problème réapparaît, une des cartouches ne fonctionne pas correctement. Suivez la procédure ci-après pour déterminer quelle cartouche ne fonctionne pas correctement.
  5. Réinsérez la cartouche noire (ou photo).
  6. Si l'erreur :
    • réapparaît, remplacez la cartouche noire (ou photo) par une cartouche neuve.
    • ne réapparaît pas, réinsérez la cartouche couleur.
  7. Si l'erreur réapparaît, remplacez la cartouche couleur par une cartouche neuve.
Aug 31, 2009 | Lexmark Office Equipment & Supplies
When i try to play bully game on my PC i have error mesage '' Bully requires a 32 bit display, and vertex and pixel shader model 3.0 support what to do? thx russ
Apr 28, 2009 | Toshiba Satellite U300-ST3091 Notebook
Graphics card
May 14, 2008 | Dell Inspiron 8500 Notebook
Computers & Internet Logo
310 people viewed this question
David Payne
David Payne
