posted by rickdrwa on May 20, 2007
we were sitting watching tv an i went to change the channel an now the reomte willl not do anything , i changed the batterys an still it will not do anything
2 Other Users Have The Same Problem
Comment by beetle1059, posted on Jul 05, 2008
After replacing battery the light remains on and nothing will happen
Comment by Guest, posted on Jun 07, 2008
I have a Toshiba television, and a RCA remote. I cannot get it to work,I think I need a code, I can't find the instruction manuel, please help!
Best Solution
posted on May 25, 2007
Remote controls does not use laser diode. the IR diodes in remote control normally do not die as the voltage from the battery is too low (3.= volts)
Your remote control is programmable, the code must have been erased what the battery wa replaced.
You must again enter the code for the TV model that you are using. If you do not have the manual, its a problem.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for RCA Remote Control
Email this problem
Email this problem
Can you Help with these Remote Controls problems?
RCA (257003) Remote Control
Broksonic TV code for RcA...
I justd wondering were there... Answer This...
Repair Service
Find Remote Control Repairman Near You:
Find Parts
