Question about Air Tools & Compressors
Grimmer schmidt 125
Compressor side if engine will pump to 125 but when running valve open from tank to tool will drop dwn to 30 cfm unless you cut valve part shut
  • 65 Answers
SOURCE: 28 gallon compressor....answer to your question about my problem
your regulator internal filter could well be blocked ,isuggest that you drain the tank fully and remove you regulator,check that tank is clear of rust or scale if all is clear then strip and clean your regulator
assembly or replace with new,problem should be gone all the best
this might be a silly question but the needle on your pressure guage couldnt be stuck?,have you drained your reciever?
Posted on Dec 08, 2008
  • 1388 Answers
SOURCE: Craftsman 25 gallon compressor wont cut off
The pressure switch has snap action contacts that are opened by a diaphragm pushing against a spring mechanism. Unplug the compressor and remove the cover to the switch and look for the contacts. Make sure that they are not welded together from use. Move the on/off lever to see if they open and close. You may have welded contacts or broken mechanism within switch. A factory replacement is expensive, however if you are a tinker-er you can use a lower price generic pressure switch available on ebay. Switches are sold by pressure range, you need a 120#. Fittings may need tweaking. Enjoy
Posted on Dec 12, 2008
  • 1388 Answers
SOURCE: unloader valves
Yes, your compressor will work just fine with a Load Genie continuous run unloader from www.grainger.com. The part number is 4tk14 with a cost of about 45.00. This unloader has a built in check valve so you can remove the present in-tank checkvalve and save it for later use. All that you need to do is install the unloader at the tank and compressed air in to top of valve. (you may have to buy extra fittings to make it work with your tubing size) Adjust valve to open just before the pressure switch cut-off setting. The unloader will bypass the compressed air and will have less stress on the motor. You will not need to use the present unloader at the pressure switch. The only caution is to manually unload the Load Genie upon initial start if there is pressure in the line. Good Luck with your project.
Posted on Mar 31, 2009
  • 1388 Answers
SOURCE: Compressor is building up pressure very slow.
It could very well be the valve plate however before you order parts take a look at the cylinders. Unplug the unit, remove the cover from crank side and turn the compressor by hand till the/a piston is at top of stroke. Examine upper cylinder for scratches /wear or failed vinyl piston ring. On oil-free compressors, dirt and grit is sucked-in from the bottom of the cylinder and causes leaks between cylinder wall and piston. If scratched, air pressure is leaking down thru cylinder wall. Failed reed valves cause a pulsation at the intake port (air seems to be pumped out the intake). If you see a model number anywhere on the pump that begins with " WL", your pump is made by Campbell Hausfeld. Parts can be ordered from www.chpower.com. other-wise order parts from sears parts. Cylinder kits are around $40. Good Luck on the repair and email if you have questions.
Posted on Apr 02, 2009
  • 256 Answers
SOURCE: Drain valve on air compressor won't open or close
I would use an ajustable wrenck to try and open the valve. Being at the bottom and in the water, this is a common occurrence. to replace the valve, there is a Hex nut outer fitting (part of the valve) that you have to remove right by the valve "T" handle. Put a wrench on this and remove the complete valve. It too will be very hard to remove. When you install the new valve, use some anti-seize compound to make future removal easier.
Posted on May 31, 2009
Why does compressor push oil through air filter when it shuts down ?
Minimum pressure check valve is bad. when unit shuts down air pressure goes back thru compressor and pushes oil out the air filter.
Jun 02, 2015 | Ingersoll Rand UP6-20-125 120 Gallon...
Ridgid mobil airpressure switch trouble
This condition will occur when the in-tank check valve is stuck open. Pressure from the tank increases load on the motor by flooding the pump with tank pressure not allowing motor to start thus reset opens. Easy test. Run compressor for one minute then unplug cord from wall. Remove hose at the check valve and test for leak with soapy water. If leaking remove valve and attempt cleaning or replace with generic valve. Cost about $20. Good luck.
Sep 08, 2012 | Ridgid Compressor With Toolbox On Top
Poor air compression
I would guess from the info supplied that the pressure switch is shutting it down at 125. Most piston type compressor only pump a max. of 175 unless it is a special high pressure unit. Also it may be shutting down on high amps, high temp etc.However with all that said Piston units are positive displacement, meanning that it should pump until something gives. Start your unit, close the discharge air valve and see what it pumps up to. May have to adjust pressure switch to get over 125. If unit runs and runs and just will not go over 125, you probably have a valve going bad. Do you have a safety lifting. if so another indication of a bad valve.
Nov 27, 2011 | Ingersoll Air Tools & Compressors
Grundfos JPF4A pump. takes a long time to get up to prime then once it kicks in after running water it gets to 50 shuts of but drop pressure instantaneously and kicks back in again. The constant on off...
The check valve is bad. When the system builds up pressure and shuts off the check valve prevents water from dropping back down the well line. When the check valve goes bad water drops back down the well line and siphons water back out of the well tank causing the switch to kick on and off constantly. The check valve will between on the well line coming from the drop pipe. It may be making a constant rattling noise as pump is running. Replace the check valve and you should be fine. Also check the pressure in bladder tank it should be 2psi below the "cut-in" pressure for the switch.
RJ
May 22, 2011 | Grundfos Plumbing
I have an ingresoll rand air compressor model # 242-5D, it has two motors and for some reason one does shut off when it hits the right amount of pressur at 150psi the second continues to run until the...
Does it have separate compressors on tank?. You probably need to adjust cut in and cut out pressure switch. I have seen several air delivery systems that utilize 2 separate compressors, this allowed a backup if the one online failed. The units had unloader valves and the compressor never stops running. A call for air pressure would close unloader valves and unit would pump up and the the valves would unload.
Jul 28, 2017 | Ingersoll Rand - Rand Type - 30...
Hello , i found an awesome deal on the internet for an air compressor , its a briggs and stratton 15 gallon and it produces 4.2 cfm at 90 psi and 5.1 at 40 psi and it may run up to 125 psi. This is enought...
Too small,on CFM
If your spending less than $400 to 800,forget it
I had a Campbell Hausfeld for 30 years,with 20 gallon
I replaced it with an upright,30 gallon
I do not use an impact on wheel nuts,ever,and I use a torque wrench set at 80# going on.
That has worked for me,damage free for 35 years.
What kills the air,is the air chisel and worse,the cut off tool,which you will use the most.
Make sure what ever you get, uses oil,the oil less units last about 3 years.
Two stage is best,but I still have a single
Has to be wired for 220 volt,unless you like paying the electric bill
So hope you have circuit breaker and 1900 box branch circuit wiring experience
Forget the gas engine,unless your going on the road every week
You need about a steady 100# to really run any air tool--so that translates to about 10 CFM,little pricy
Oct 22, 2010 | Briggs & Stratton Air Tools & Compressors
Compressor short cycles during operation. (load / unload). hose to guage and pressure switch ok. what could be the problem?
The pressure switch has an adjustment for the low pressure cut in and the high pressure cut out. If the pressure range is set too close the cycles will be short. You need to work out which setting is wrong by looking at the pressure guage when it is cycling and adjust the pressure switch accordingly.
Sep 06, 2009 | Ingersoll Rand UP6-30-125 120 Gallon...
I own i 20 gal. clarke abrasive blaster. My problem is that i can only blast for about 30 seconds and then have to wait almost 2 minutes for the pressure to build back up
Sounds like your compressor doesn't have the cfm to keep up with the blaster. Blasters use a lot of air. The cfm of your compressor should match or exceed the cfm of the baster. Try a bigger compressor.
Good Luck!
Aug 20, 2009 | Clarke Power Products Clarke 10 Gal....
Air Tools & Compressors Logo
683 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
