Question about Bissell CleanView 3596 Bagless Upright Vacuum
I have the Bissell upright cleanview bagless vacuum cleaner. My belt broke and someone else took it off. I bought a new belt but do not know where it goes on the cleaner. Please help
Easy to do. Unplug the vac. Turn the vacuum over and look for three finger latches on the bottom behind the brushes. Unlatch these and pull the faceplate off. Then, grab one side of the brush and pull straight up (they just sit in grooves on the sides). Once the brush is up, then pull it out of the belt. Look towards the back of the vac, the belt rides on a shaft. There is room to work the belt off to the side.
Replace the belt on the shaft, onto the brush, and then fit one side of the brush in and push down the other side. Rotate the brush to center the belt (you did unplug it, right?). Put the plate back on, front first, the little tabs will go into the slots. Then push it down firmly, latching the three latches. Take the time now to completely pull everything apart and clean it, including the hose, running a coathanger through it to make sure it's clear. You're done!
Posted on Dec 21, 2009
  • 76 Answers
There is usually a diagram on the bottom where the brushes are.
Posted on Aug 22, 2009
Walmart return policy
It probably has hair and dirt in the endcaps which has seized the brush roll. You will need to. Buy a new brushroll and. Belt
Jul 31, 2014 | Bissell Cleanview Helix Upright Vacuum...
Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
Bissell 8975-R CleanView Bagless Upright Vacuum - motor is loud when vacuuming
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span>Hi,<br />Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...<br /><br />Bissell Bagless Upright <a href="http://www.fixya.com/support/t4975919-vacuum_pick_up" target="_blank">Vacuum</a> not working<br /><a href="http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not" target="_blank">http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not</a><br /><br />heatman101 <br /></span></span>
Aug 26, 2010 | Bissell 8975 CleanView Bagless Upright...
Bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Jul 07, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Foot operated release "spring" is broken. Replaceable?
Remove the pieces of the old spring and take it to any OSH store, they have an assortment that will likely have one that will work.
Oct 20, 2017 | Bissell 3590 CleanView Bagless Upright...
Roller wont spin
The bearings in your brush roll are bad. Replace the roller and walla problem solved!
Apr 13, 2009 | Bissell CleanView II Plus Upright Bagless...
Where does the belt go?
If you are looking straight onto the vacuum it goes on the right side around a small metal bar and then around the brush. Make sure that when you push the brush up that both caps are twisted in the correct position so it will slide easily into the grooves.
Jan 04, 2009 | Bissell CleanView 3596 Bagless Upright...
Roller and belt changing need schematics
How to change the belt on the Bissell Clearview?
Sep 02, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell CleanView 3596 Bagless Upright Vacuum Logo
173 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
