Question about Galaxy Radios DX- 88HL Base CB Radio
Galaxy 88hl frequency display only has decimal point, channel readout fine
Has c option frequency display board. No readout on the frequency other then the decimal point, channel readout is fine. Transmits and receives fine.
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
On the face plate is a button for the counter ,try pushing it several times to see if the dot moves. As long as the channel display is reading the correct channel you should be ok but you want to correct this problem . If you can't correct it contact Galaxy and they will have a tech talk to you.
Posted on Mar 16, 2015
Shuttle83
  • 1139 Answers
SOURCE: Galaxy 88hl stuck on 24.178
Hello radiogeek,
it sounds like you have a bad voltage regulator since you are indicating that the voltage adjusted by L17 is random. Check all of your voltages from the power supply (regulator side), and make sure they are stable. You will find that you may have a bad voltage regulation circuit or a bad capacitor in the unit power supply.
Thank you,
Shuttle83
Posted on Nov 28, 2007
ButtFuzz
  • 463 Answers
SOURCE: GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
Could also be off-frequency.
RX circuit mis-aligned.
(or, as always... snake in radio... worst problem of all :)
Posted on Mar 20, 2009
  • 8 Answers
SOURCE: used galaxy 88hl
If you have a receipt for it and you had it less than 2 years it can go to Galaxy in Calif. if is defective. Just go the the Galaxy tech support webpage and follow the directions for an RA #. They do good work. If you want to send it to a top notch repair shop try Dons CB in PA. They are a real Galaxy warranty service center. The # is 814-898-1046
Posted on Mar 29, 2009
SparkyNZ
  • 43 Answers
SOURCE: it transmits off frequency is there a adjustment and also the frequency counter goes crazy at times
To add 10Khz to your transmit frequency:
FIXED/OFF/+10KHz SWITCH:
The left position puts the radio on
one of the three fixed channels that is selected by the channel switch
(6,19, or 21). This over-rides the channel selected by the 40 channel
knob. The right position adds 10KHz to whatever frequency you are ON.
In the middle, both features are OFF.
Otherwise, a radio tech would be able to retune the frequency inside the radio.
After adding 10KHz to your frequency, use the SWR control to check the SWR of your antenna.
Here's how:
SWR CAL CONTROL: Normally this switch is set to “PO”. Then,
during transmission, the meter indicates output power. To read SWR,
rotate this knob during transmission until the needle moves to the “SET”
point on the SWR scale. Then, while still transmitting, set the R.B./SWR
switch to SWR.
Ideal SWR is 1 but you'll want to be as near one as possible. An SWR of 1.6 or greater will make ineffective use of your antenna.
If in doubt, a radio tech has the required meters and tools to adjust the SWR/Tuning of your antenna.
Posted on May 10, 2009
  • 64 Answers
SOURCE: not receiving at all
Call 706 270 3829 Galaxy Expert!
Posted on Aug 28, 2009
How do I program a realistic 2029pro
These steps were listed on their website:
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency appears on the display one digit at a time.
7. To program more channels repeat steps 3-4. (IR-07/29/96)
Nov 11, 2014 | Radio Communications
Changing colors on a Galaxy 88 or DX-88HL or DX88
  • There are no white ones at this time. Only Red, Green and Blue on the frequency displays. If you have any other questions please feel free to ask.
Oct 20, 2011 | Galaxy Radios DX- 88HL Base CB Radio
On my radio I need the settings for the knobs because other people can hear me but I only get static and cannot hear them. Thanks
Band should be E Band high/low button on high 10 khz off AM selected
To check that you have done this correctly frequency counter will read 27.185 plus or minus 5 khz. This is of course proved you have a radio that is converted for 11 meter cb frequencies.
http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm Frequency Conversion is the channel expansion mod/conversion
Sep 16, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Haven't used my dx-88hl cb for years. what d9 i set the band on?
I'm not going to be corrected on this as i'm tempted to say A or C and sometime D. Instead i would say switch channel to 19 then watch frequency counter as you change band selector until you find 27.185 and you have arrived.
Dec 27, 2010 | Galaxy Radios DX- 88HL Base CB Radio
My galaxy dx 88 hl makes a laoud noise when you key up and the frequency counter it's off. Channel 19 is on channel 18.
my galaxy 88 cb makes a popping noise through the speaker when I key up how do I solve this problem?
Jul 15, 2010 | Galaxy Radios DX- 88HL Base CB Radio
Cant get know help to program my scanner
Programming the BC60XLT is simple and straightforward:
- Select the frequency to program.
- Select the channel that you wish to program it into. You can press MAN and the channel number, followed by MAN, or just repeatedly press MAN until the desired channel is displayed.
- Enter the frequency, including decimal point (for example, 156.065). The decimal will display as a dash.
- Press E. The frequency is now programmed into the scanner memory, and you can repeat the process to program any channel.
For more information on your scanner, you can download/print the operating manual here:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Apr 25, 2010 | Uniden BC60XLT Handheld Scanner
How do i re-program my scanner
To enter a known frequency into memory:
- With the scanner powered ON, press the HOLD key.
- Enter the number of the channel that you want to program or re-program, followed by FUNC + PGM. The channel number will be displayed.
- Enter the desired frequency, including the decimal point.
- Press E to enter the frequency into memory.
- Press HOLD to advance to the next channel.
For more programming options, you can download/print the scanner operating manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, along with other useful scanning onformation, visit:
Bill B
Apr 14, 2010 | Radio Shack Pro-83 Scanner
What steps do i take too program frequences. what are the frequences for charlotte north carolina?
with the scanner on, push the "man" (manual) button. If the scanner was scanning it should stop on one channel . Push the up or down arrow key until you get to the channel you want to program. You can also use the keyboard for direct access to a particular channel i.e. push "1" "4" "9" and "man" to jump to channel 149.
Once on the channel you want to program, push "prog" (program) then the frequency you want in that channel, including the decimal point. Push "ent"(enter). Your desired frequency should be displayed. Don't forget the "." (decimal point) or the scanner will tell you "error". Move to your next hannel to be programmed and repeat. If you put in a frequency outside of the radio's capability, you wil get an error message.
To find frequencies, look on the internet. The best site I have found is
http://www.radioreference.com/ .
Oct 27, 2009 | Radio Shack Pro-2054 Base Scanner
How do i program my realistic pro-2025 scanner
scanning.
Jun 03, 2009 | Radio Communications
Galaxy Radios DX- 88HL Base CB Radio Logo
120 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
