Question about Stihl 064 Chainsaw Oil Pump
How do I adjust my stihl 064 oiler - Stihl 064 Chainsaw Oil Pump
4 Suggested Answers
  • 14 Answers
SOURCE: Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
Posted on May 10, 2010
  • 100 Answers
SOURCE: how do I adjust the chain oiler for a Stihl 043?
if it doesnt have a flow screw.u dont. pull pump plate off and clean and sometimes replace pump.
Posted on Oct 22, 2012
brimax7576
  • 344 Answers
SOURCE: How do I adjust the oiler on a ms271 stihl chainsaw saw
Alot of chainsaws have a dial most of the time on the bottom of the saw. Using a flat head will do the job... there should be a little indented drawing of a chain and oil drop where the dial is
Posted on Oct 18, 2015
Will a 56mm cylinder kit fit a 064
http://sawparts.ca/products/stihl-064-066-ms650-ms660-big-bore-cylinder-kit-nikasil-56mm
It seems that YES a 56mm aftermarket cylinder is available for the Stihl 064. Looking at the kit you need to just replace Cylinder, Piston and rings, bearing bush and clips. Worth also replacing the base gasket too.
May 01, 2016 | Stihl Models 064, 066, Ms640, Ms660
Is the LA adjuster for oiler to chain& what 1/4 turn per run to check ratio??
PDF]STIHL MS 261/261 C Chain Saw Instruction Manual ' STIHL ...
www.stihlusa.com/.../ms-261-261c-chain-saw-instruction-manual.pd...
Stihlde la rueda dentada usada y de otros ... this manual to operate your chain saw. ..... 1/4 turn). Misaligned, damaged or broken cap. N. If the cap does not drop fully .... adjust the chain while the engine is running! Warning! To reduce the risk of fire ...... bolts and screws except the carburetor adjustment screws after each use.
[PDF]STIHL MS 200 T Arborist Chain Saw Instruction Manual ...
Dec 15, 2015 | Stihl Garden
How does one replace the chain oiler in a 0009 Stihl chainsaw?
from stihl documentation it does not seem that you can replace it. I have appended the manual for you and an article dealing with chain oil delivery system for 0009
Stihl Chain Oiler Trouble
How to Unstop the Oiler on Stihl Chainsaw
http://www.stihlusa.com/stihl_ownersmanuals/009_manual.pdf
Jan 26, 2015 | Stihl Garden
How to adjust chainsaw oiler on stihl MS230
you cant. the oiler on an Ms230 is preset and non adjustable. Make sure the oil worm gear isnt damaged
Apr 13, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Stihl 024 over oiling
Your oiler is probably defective, or perhaps it just needs the adjusting screw to be turned in a little to restrict some of the flow.
Jan 11, 2012 | Stihl Garden
Cannot find oil regulator on stihl 024
There is no oil "regulator" only an oiler with a screw that adjusts the flow, that is found below the saw, and is fit for a slotted screwdriver.
Jan 11, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Dont no how to ajust the ioler for the bar oil uses a tank of oil to a half tank of fule burned
what brand saw? Stihl saws are made to run Stihl oil. If you are runnin other oil, the viscosity wont be the same as the pump is designed for, and the oiler may pump more then it should. The oil adjustment screw should be a single flat head set screw on the underside of your saw near the sprocket. Alot of saws are not equipped with an adjustable oiler. Professional saws and larger displacement saws will have the feature.
Sep 15, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Too much oil is being delivered on the chain, how do I adjust the oiler on my Stihl 038av super?
This is Stihl's manual showing the proper adjustment for the oiler. Flip the saw on its side, chain and bar side up, and look for a flat head screw.
Clockwise rotation on any saw is more oil, and counterclockwise will be less oil.
Nov 25, 2010 | Garden
Hello, my stihl 017 chainsaw is over oiling the bar, is there any adjustment I can perform, thanks, Gareth.
No oiler adjustment. Sorry
http://www.stihlusa.com/stihl_ownersmanuals/017_018_Manual.pdf
Are you using bar oil or something lighter? Stop by your local Stihl dealer (leave your saw in the car), give him a latte, and chat. He might have an idea or 2. He will not be chatty on any weekend or if there is a perspective sale in the store, HTH
Lou
Jan 19, 2010 | RTO Spur Sprocket For Stihl 017, 021...
How to adjust chain bar oiler
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl 064 Chainsaw Oil Pump Logo
109 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
