Lamona hja 8553 door wont open - Washing Machines
ftw1952
  • 10319 Answers
SOURCE: I need the user manual
http://www.manualsnguides.com/search.php?cmarque=HOWDEN&modele=HJA%208552
Posted on Aug 24, 2010
  • 6277 Answers
SOURCE: Lamona Washing Machine HJA 8514 Half way through a
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 27, 2011
SOURCE: My Lamona integrated washing machine
Hi Guys,
My Lamona washing machine is also stuck on rapid wash? Dis you get it resolved?
Kind Regards
Posted on Sep 02, 2011
  • 6277 Answers
SOURCE: Lamona hja 1514. When on
First thing to do is to adjust its balance/level by following my pre-typed guidance notes ;-0)
I shouldn't worry about its change in design/build, certainly not for now!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
John C
Posted on Sep 13, 2011
SOURCE: I was using my Lamona
Hi Karl
Did you get this issue resolved as I have the same problem?
Cheers
Posted on Oct 02, 2011
How do you remove and adjust the oven door to sit squarely on the rubber seal Its a Lamona HJA 3220
open door half way,pull out on the door,it will slide off the hinges
May 09, 2015 | Ovens
Lamona hja 8553
Unfortunately Lamonoa doesnt make washing machines. Its a wood fitting company that uses various machines. They reccomend this manual
http://pdfsb.net/readonline/5a6c4244656739355758422b436e6c6a55554d3d
for the 8553.
You have to read online..through the pdf
Mar 20, 2014 | Washing Machines
No temperatures on the oven
Easiest thing to do is to Get your Model Number, log onto www.searspartsdirect.com and order the new knobs... Or go to your local appliance repair center or Appliance parts store and order them and you will be able to get fix it for the future.
Download LAMONA HJA 3300 HJA3300 User Guide English
Mar 03, 2014 | Ovens
Lamona hja8630
How do I remove the integrated door af a lamona hja 8630
Jan 01, 2014 | Dishwashers
Lamona hja 8631
please see the video attached and fix it. Merry Christmas.
Dec 18, 2013 | Dryers
Lamona HJA8553 Washing Machine door release has suddenly stopped working!! Is there an emergency door release to get my wet washing out??? tried turning off at the wall in hope of resetting the machine...
My Lamona integrated washing machine HJA 8553 has a nasty smell coming from it like an old damp mop its making the whole of the house smell any ideas why
Jun 30, 2011 | Washing Machines
Have misplaced manual for lamona washer dryer HJA 8704. How do I find the setting for tumble drying only
I have scanned my HJA 8704 Manual and put it here
https://docs.google.com/open?id=0By3DbWv5t3T-WHR4OGJMMkZ5Tk0
Jun 21, 2011 | Dryers
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
