Question about Lexmark JetPrinter Z605 Color InkJet Printer
Printer jam My printer keeps jamming. I see nothing that is stuck in the wheels. It keeps getting crumpled on the right side & then nothing.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
Canon printer error code 6A81
Solution 1: This is a purge unit error.
There maybe something jamming the purge unit or just a absorber out of place which is picking up on the carriage preventing it from moving correctly.
Try to move the carriage away from the purge (its where the printhead/carriage parks its self on the right side of the machine) with no resistance then you can shine a torch into the machine and look at the purge unit.
There maybe crumpled paper jammed in the purge.
If all looks well, the purge unit may be defective and had to be replaced.
Solution 2:
The wiper on the purge may have stuck. It slides back and forth and they have been known to stick.
Push it with a long screwdriver to see if it moves.
Solution 3:
Something is blocking the printer inside. It could be a paper jam or a foreign object.
Check using a flashlight, to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen.
If there is nothing obvious, unplug the printer power supply.
Dec 02, 2015 | Canon PIXMA MX882 Wireless All-in-One...
The paper gets jammed it starts to go in but then it like crumples up and gets stuck
check if the back panel that you can remove to check for paper jams has come loose. If it is the paper can get snagged on it and jam. I don't have your model printer but most printers have this access panel. It is usually the same part that can be replaced with a special part to enable two-sided printing.
Jun 29, 2010 | Epson Stylus DX4450 All-In-One InkJet...
I Have a Canon MultiPASS MP390, which is showing a paper jam fault, when I print the paper is gets fed wrong. It seems to grab the paper on the right side and pull down which crumples it, then it tries to...
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
My hp deskjet 6988 all of a sudden has paper jams as a sheet feeds...the lead right edge gets crumpled and jams
try opening up the printer make sure nothing is stuck on that end
May be try changing the rotors on the printer...
Might be time to get it serviced i say .. seems to be more of a hard ware issue than anything else
Feb 03, 2010 | HP Office Equipment & Supplies
Printer Jammed
If you unplug the machine when the printhead is out of the corner, you can shine a light in and see where the crumpled paper is, usually on the right side where the cleaning assembly is.
Aug 12, 2009 | Brother MFC-5840CN All-In-One InkJet...
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
Jul 21, 2009 | Office Equipment & Supplies
Photosmart 3210 all in one printer
Turn the printer around and open the door you will see paper jam.
Jun 30, 2008 | HP Photosmart 3210 Printer
Paper jam at fuser unit section
answered here :
http://www.fixya.com/support/t636850-paper_jams_fusion_stage
also, if the paper stuck in FU is straight not crumpled and will come out easily then make sure that the 2 knobs located at top of the FU are in right position.
Jun 22, 2008 | Konica Minolta magicolor 2400 Laser...
Carriage jam
This can be many things, but inspect the paper path for anything stuck. remove the cartridges with printer off and see if you can manually move the carriage you may need to force it a little but not allot, sometimes it may jump a gear causing this error.
move the carriage away from home position and turn on, the printer should reset the carriage position.
hope this helps
Jan 07, 2008 | Office Equipment & Supplies
Lexmark JetPrinter Z605 Color InkJet Printer Logo
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
