Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
No water coming down tube in kenmore ice maker
My kenmore ice maker is not working, there is no water coming out of tube into ice maker
  • 163 Answers
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Posted on Jan 04, 2009
Ice maker not working properly it stop working. how can i get this ice maker back working again.
I suggest you look at where the water comes into the ice tray - there probably is a small black tube. Check the tube to see if it is "frozen" - with ice. I've taken a blow dryer to the ice maker to melt all the frozen lines.
Dec 26, 2012 | Kenmore Coldspot Freezer Knob Part 532015...
Ice maker stopped working suddenly. model no 106.56646500. Water is getting to the door but not coming out of the tube to the ice maker.
If you are sure the tube is not frozen the replace water valve. Also put 120v to the freezer water valve side to so if water goes up to the ice maker.
Mar 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side: ice maker works...ice
Probably a broken plastic tube from the solenoid valve to the water outlet tube. It will stay dry until you try to get water then it may take a few days to dry out.
Good Luck,
Gilsh
Nov 27, 2009 | Kenmore 57029 Side by Side Refrigerator
KENMORE ICE MAKER DOESN'T WORK. WORKED WHEN IT WAS NEW. NO WATER.NO PUMPING NOISE.
Good day,
The first step is to check the ice maker.
Pour water in the cavity of the ice maker until near full. Turn ice maker on and close freezer door and wait 2 hours. If it dumps ice then you can exclude the ice maker. If no action, and the water is still frozen in the cavity the ice maker must be replaced.
If the ice dumps then follow these steps.....
You want to check the water supply line to the machine from the house supply.
I prefer to shut the whole house down with the shut off valve at the meter. Disconnect the water line to the water valve at the bottom rear of the fridge. Point the open end of the water line into a bucket, and while watching have someone turn the water to the house on for a 10 to 15 second count. Water should come out of the line forcefully. If not replace the line and it's connecting valve.
If water supply is good, then replacing the water valve itself should solve your problem.
P.S. In rare occasions, the file tube from the back of the refrigerator to the inlet of the rear of the ice maker can build up with ice. You have to remove the ice maker to check this. If there is ice in this tube you have to melt it out.
However, caution using heat, as from a hair dryer ect. Heat from these devices can do a lot of damage to the hose and other plastic components in that area.
Nov 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker making ice
pull the water supply tube in the freezer out and see if it is frozen up,let me know more-mike
Oct 10, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
KENMORE ICE MAKER STOPPED WORKING
MAKE SURE THE ICEMAKER IS ON,ON OFF BUTTON OR LEVER IN DOWN POSITION,CHECK TUBE BEHIND ICE MAKER PULL IT OUT LOOK IN IT LOOK IN FREEZER HOLE TO MAKE SURE IT'S NOT FROZE UP,CHECK WATER INLET VALVE ON LOWER BACK OF FRIG.,LOOSEN CONNECTION TO SEE IF GETTING WATER,IF WATER IS COMING OUT IT IS A BAD WATER VALVE ONLY ONE SIDE TO WATER DISPENSER IS WORKING,VALVE IS NOT OPENIBG TO ICEMAKER SIDE,THANKS-MIKE
May 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
Oct 19, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
367 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
