Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Bosch logixx anti crease end toooo long how to stop
3 Suggested Answers
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
  • 6277 Answers
SOURCE: my Bosch Logixx has stopped
Bosch 'F18' decodes as 'pump/drain out time' so I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my comprehensive guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 29, 2011
Bosch vented dryer stops after a few minutes with drying and crease hold/end lights flashing
It could be that it is over heating. I would check the vent tube to see if it's clogged or check the part where you hook up the vent to the dryer
Nov 26, 2015 | Bosch Dryers
Keeps stopping
try a different cycle anti crease is not a full term cycle
May 22, 2015 | Dryers
Bosch logixx 10 tumble dryer
This is not a good sign. You should check to see if the door switch is bad. If it is not that then the controller needs replaced.
Jul 08, 2013 | Dryers
Mid cycle it turns off and beeps and the anti crease/end button flashes
Possibly a blockage pump or drain outlet, check the filter behind the flap (bottom right on the kick panel).
May 31, 2013 | Bosch Logixx WFT 2806 Front Load...
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
Sep 24, 2010 | Washing Machines
My bosch logixx dishwasher quick wash has never
i would change the control board or control module. thermador .com will let you order it.
Apr 09, 2010 | Bosch SHU9915UC Dishwasher
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Machine is locked
to open your door make sure all the water is out of your drum if not get the outlet hose and place on the floor into a bucket if water comes out than your pump is either blocked/faulty
Aug 12, 2007 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
