Question about Masterbuilt 20070106 Electric Smoker
Masterbuilt electric smoker circuit breaker - Masterbuilt 20070106 Electric Smoker
  • 72 Answers
SOURCE: MASTERBUILT GAS SMOKER
Here is the link for the maunel online in pdf format
http://www.masterbuilt.com/pdf/manuals/7%20in%201%20Smoker.pdf
the main website says individual parts will be availible for sale soon, main website is
http://www.masterbuilt.com/index.html
hope this helps
Posted on Nov 09, 2008
SOURCE: Element won't heat on Masterbuilt smoker
I called Masterbuilt and they said they no longer sell the elements. you have to buy the cabinet @ $189 for the 40" model. I decided to pull my element and see if i could find one that would work by going to an appliance repair parts store.
When i pulled the element, i found that the terminal that plugs into the element was burned/melted in two. i replaced the terminal end, pluygged it in and tis working fine.
to remove the element, you need to remove the element cover/chip loading chute first. its easy, 2 sheet metal screws and 2 nuts and 2 machine screws. one of the nuts/machine screws is a little hard to get back on when you reassemble but it can be done. after the cover is removed, you will see 3 screws where the element goes through the back wall. only removed the left and right ones. do not loolsen or remove thecenter one. after you remove the 2 screws, you can coax a small amount of the wire leads out into the open and you can inspect them to see if they are broken.
if the problem is truly a bad element, you will have to find an element somewhere. i cant help with this except to say that Masterbuilt customer service says they are negotiating with their supplier to see if they can sell the elements seperatly. they hope to have that resolved by summer.
hope this helps.
D Smith
Posted on Dec 09, 2008
heatman101
  • 43501 Answers
SOURCE: Electric smoker is now tripping GFCI breaker
GFCI breaker tend to wearout and become more sensitive after time and use. Motor loads are especially hard on them. Also resistance loads such as heating elements. Your smoker may be pulling a bit more electric than it used too.
Check the power draw of the smoker when operating, if it is high then fuigure out why. It it is normal then replace the braker. Use a regular breaker if the GFCI is not required, or run a cord from an outlet that is not on a GFCI breaker.
Heatman101
Posted on Jan 24, 2010
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
heatman101
  • 43501 Answers
SOURCE: can you buy a replacement heating element
Here is a pdf of the smoker book and on page 4 there is a parts list with the cust. service number to order replacement parts...there is an element kit listed there, that is what you need.
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20models%2020070206,%2020070106.pdf
heatman101
Posted on Jul 25, 2010
Smoker throws breaker
Larger breaker.... Or split breaker....what size right now??
Nov 19, 2012 | Masterbuilt 20070106 Electric Smoker
Eeaf smoker keeps tripping off
Hi sally mako...
Make sure your breaker is strong enough to handle the ampreage draw of the smoker element.
Try a different receptical with a known larger breaker...
If still kicks the breaker, then remove the electric plug from the receptical and check all connections on the element and controls to make sure they are not corroded or broken and shorting out.
Please take time to rate me
Sep 24, 2011 | Masterbuilt 20070106 Electric Smoker
I need an element for Mod: 20070106 Ser.# GA040925
You can purchase a new heating element part # 990050051 either from Masterbuilt or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/masterbuilt/
If they are still available. All of Masterbuilt's electric smokers have been plagued with electrical problems.. It's either the element or the electronic controller on the top of the smoker, that constantly fail.
Hope this helped you and thanks for choosing FixYa.
Sep 20, 2011 | Masterbuilt 20070106 Electric Smoker
I have a Masterbuilt electric smoker and have lost the instructions that came with it. Would instructions from a different smoker work with my Masterbuilt? Do you know how I might get the Masterbuilt...
Masterbuilt makes several different models of electric smokers. f you can furnish the correct model number of yours, I may can help you.
Thanks for choosing FixYa.
Aug 05, 2011 | Grilling
I NEED A MANUAL FOR MY MASTERBUILT ELECTRIC SMOKER
Here is a link to the Masterbuilt Smoke House 30" Electric Smoker, Model # 20070210. Which is what I think you have. You can download and print the manual.
http://www.masterbuilt.com/pdf/manuals/20070210%20ESQ3082%20Manual.pdf
Hope this is what you need. Please let me know.
Mar 07, 2011 | Masterbuilt Electric 30inch Smokehouse ...
Tried warming it up to smoke some jerky and when i went out to check on it it was off and won't turn back on.
Have you checked the electrical receptacle it's plugged into?
Has the circuit breaker for that receptacle been tripped?
If you have the electronic control option is that lit up?
If you answered YES to the last 2 questions and No to the first One, then that's where you need to start the trouble shooting. If that doesn't solve the problem, ten it may be in the electronics. In which case you need to contact Masterbuilt's Technical Service Dept or their Customer Service Hot Line.
Feb 10, 2011 | Masterbuilt ESQ30B Smoker
Digital panel no longer works. need source for circuit board and approximate cost
Masterbuilt Digital Smoker no longer heats up and digital display has stopped working completely. The unit acts like there is no power to it and is completely dead. By replacing the digital component will this solve my problem
Jul 01, 2010 | Masterbuilt 20070106 Electric Smoker
Heatman101
Jan 24, 2010 | Masterbuilt 20070106 Electric Smoker
Wont heat
Same thing happened to me. I talked to Masterbuilt tech support, they said it needs a new heater element, which is > $100. Hope that you're still under warranty...
Mar 30, 2008 | Masterbuilt ESQ30B Smoker
Masterbuilt 20070106 Electric Smoker Logo
194 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
