Question about Coffee Makers & Espresso Machines
Need instruction manual for Chefs and Bakers 60 cup coffee urn
How much coffee do I need to use for 60 cups
SOURCE: How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Posted on Jan 15, 2009
SOURCE: 10-22 urn
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
Posted on May 03, 2009
  • 68 Answers
SOURCE: Hamilton Beach 40540 Brew Station 40-Cup Coffee Urn, Silver
Try to see your manual.
Posted on May 18, 2009
bugsy33
  • 33 Answers
SOURCE: I have a 42 cup coffee urn. How much coffee do I
42 level scoops not full scoops
Posted on Dec 05, 2009
  • 5 Answers
SOURCE: whay is the coffee to water ratio per cup?
I have the Regal 10 to 30 cup model K7030C.
Instructions read as follows:
CUPS COFFEE
(5-oz serving) ( 8-oz dry measure)
10 ........................2/3 Cup
20.........................1 1/4 Cups
30.........................1 3/4 Cups
Hope this helps
Posted on Jan 18, 2010
I need an instruction manual for my Farberware 36 cup coffee urn.
Hello!
I think that this instrucion manual will work for you: http://www.useandcaremanuals.com/pdf/FSU122.pdf
It would help if you mentione the model of the coffee urn.
Greetings!
Mar 25, 2016 | Farberware Coffee Makers & Espresso...
How much coffee to add for 20, 40, 60 cups of coffee in the 60 cup DeLonghi coffee urn?
I like my coffee pretty strong and I use 2/3 cup coffee to 10 cups of water...
You may be able to use 1/2 cup to 10 cups if you don't want it too strong...
You must experiment a bit as different coffees will vary also...
heatman101
Apr 30, 2011 | DeLonghi BAR 140 Espresso Machine
How much coffee would it take to make the 55 cups in this coffee maker, and can you use the same coffee as you use for drip machines?
Your model sounds like the West Bend 59055 - Large Coffee Urn, 60 Cup.
The User Manual for your coffer urn can be found here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
Instruction for making coffee can be found on page 5. For 55 cups is would take 3 1/4 cups of coffee.
Use an electric perc or regular grind coffee; if you grind your own this should be a medium to coarse grind.
Do not use 'drip' or finely ground coffee as this could plug the drain holes in the basket and cause the urn to flood.
Mar 24, 2011 | West Bend (59055) Stainless steel 60-Cup...
45 cup coffee urn How much water and how much coffee?
20 cups of coffee needs 2 cups of coffee grounds
30 cups of coffee needs 2 1/2 cups if grounds
40 cups of coffee needs 3 cups of grounds
45 cups of coffee needs 3 1/2 cups of grounds
1 cup brewed coffee = 5 fluid ounces
* use standard measuring cups
Oct 22, 2010 | Salton Melitta MEU45 Stainless Steel -...
How do i make coffee in a 60 cup urn...i have no instruction manual
Hi, 2 scoops of coffee for every 3 cups. Then make adjustments to taste.Ron
Aug 16, 2010 | Coffee Makers & Espresso Machines
Need instructions for use of Farberware 55 cup Coffee Urn
Hi 2 scoops of coffee to 3 cups not mugs. Then take it from there, adjust to your liking. Ron
Apr 16, 2010 | Faberware 12-55 Cup Coffee Urn
Instruction manual for Bakers & Chef 60 cup coffee urn. I need to know how much coffee (in cups) to make 60 cups of coffee. I misplaced the instructions that came with the coffee urn. Thanks, Tom
I use 1/2 cup ground coffee for 12 cups. I make for the church and guests and everyone seems to like it. I use the same amount for decaf or regular. Hope this helps.
Oct 02, 2009 | Coffee Makers & Espresso Machines
10-22 urn
Dec 17, 2008 | Faberware 10-22 Cup Coffee Urn
Coffee Makers & Espresso Machines Logo
333 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
