Question about HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop
Reset Ram? I need to know how to reset my RAM on my desktop, my computer won't turn on and when I took it to Geek Squad they said it just need a RAM reset. But it went off again and won't come on. Help please.
  • 1 more comment
  • julian_nicol Jan 04, 2009
    The computer won't turn on at all, I took the battery from the mobo out for a while and when i put it back in the led light on the mobo is on and there is a flashing orange light on the power button, but the computer still won't turn on.
  • sunanda69199 Oct 22, 2012
    oh my god same problem occurred for me also.
  • onewilliam12
    onewilliam12 Jan 28, 2013
    hold alt and press F11 repediatly
    Scholar:
  • 39 Answers
By default your RAM should reset every time you restart your computer and all of the memory should return to the system. If this is not the case I suggest defragmenting your ram.
If you are using windows Vista I suggest inserting your OS DVD into the drive, rebooting, and running the memory diagnostic tool.
If you are not running Vista you will have to download a program such as RAM Def 2.6 Xtreme to defragment the memory for you.
Posted on Jan 04, 2009
  • Matthew Shockey
    Matthew Shockey Jan 05, 2009
    Woops. Sorry dude. Um just open your case and gently pull out your ram and stick and put them back in there proper place. That should reset it as well. Also, if the computer is flashing a red light and wont turn on, that means the ram isn't set in its sockets or its not in the right one, if your motherboard has dual channel memory. Did that to my HP DC5100 on accident one time when I was trying to fix it.
    Novelist:
  • 206 Answers
RAM is volatile, so you can not reset it. When the computer is turned off - Your rams memory is erased, completely cleared of any data.
Sounds more like a hardware issue. First thing I'd look at, power supply. but if your computer does start, try going in to safe mode.
From start tap you F8 key till you see a screen that shows safe mode - I do Safe Mode with Networking. In this mode your desktop might be a bit smaller - make temp adjustments.. If the issue doesn't ever effect you while in safe mode - then you have a virus. From what info you have given, sounds like a power issue or some other hardware issue.. Hope this helps.
Posted on May 05, 2015
Need New Motherboard and Power Supply
You said when your problem started it was making a beep? then you said you upgraded the RAM. Did you know thats the beeping sound made when its the wrong RAM. Its just a hunch but is it possible if you placed the old rams back in it might go. JUST A HUNCH OK!!!! When you took it in to see the GEEK he may have been trying to get some dollars from you and it didnt pay off.....just a hunch. If the Hunch is not a hunch you can see on the centrer of the board what kind it is. As far as the power supply is concerned what happened to the original do you still have that. What made you change. Gosh it must have emitted over the 18volts in the adapter........Im lost?
Oct 05, 2007 | Medion M3 Composer 5200 PC Desktop
I have an acer AM5621 that will not power up. When you push the power button it attempts to boot, the light flashes on, I can hear the fan starting and then goes off.
Here are some steps I would take to resolve the issues:1) Remove battery
2) Open computer to access RAM (usually there is just a RAM door on the bottom of the computer)
3) Remove RAM and attempt to power on computer.If you get a series of beeps from the computer then you most likely have bad RAM. Replace one stick and repeat. If you don't get beeps then it's that stick, otherwise try with second stick.If you don't get a series of beeps then you most likely have a bad motherboard.3) With the battery removed hold down the power button. This will attempt to reset the motherboard back to factory default (in case it's an issue within the BIOS).
If none of the above work then you'll likely have to seek a professional service (i.e. Geek Squad or something similar).
Hope this helps.
Jul 27, 2011 | Acer Aspire AM5621-EQ9300A Core 2 Quad...
Toshiba LED Power light flashing 1 blue and 2 orange
Remove the ram and re-install. If still fail, ur RAM is defective or has error.
Apr 03, 2010 | Toshiba Satellite A200-0ET00X Notebook
How to install ram in 9680c. can't get at the motherbooard
If you cannot access the motherboard, you cannot install any ram in the computer. I suggest you take it to Geek Squad or contact the computer's manufacturer to see about upgrades.
Dec 16, 2009 | HP Computers & Internet
Power light comes on but nothing on the screen.
Just open the one side of the computer cabinet and check your ram is completelty connected or not.
. Remove your RAM And check Any beep Sound . If the beep comes *********** board is OK There Can be a problem of your RAM.
Aug 25, 2009 | Audio Players & Recorders
Gateway PC screen blank, geek squad diagnosis motherboard issue
You could replace the motor board for less than $100 but I think the geek squad says the motor board is bad on every computer that doesn't start right up for them so I would have someone else look at it first. Or just get a new computer at walmart for like $300
Jul 23, 2009 | Computers & Internet
No Network Connections After Repairs
Ah, yet another NASTY Geek Squad experience for the recordbooks...if you bought the computer at Best Buy, they should have been able to diagnose and replace the bad RAM stick. Replacing the RAM stick shouldn't have caused the network connections to be lost. You can go into your control panel and set up a new connection in "My Network Places", or "Network & Sharing Center" (the name depends on which operating system you have. The wizard will walk you through creating a new connection, so you shouldn't have any problems.
More than likely, your computer was never sent to Gateway. They should have records for that serial number on your computer as to any repairs that were done. And it's a good idea to register your computer with Gateway anyway for severe issues that come up. I would also recommend finding a local computer repair shop if you can -- their business depends on the quality of their work and they're usually cheaper and cause less headaches than chainstores, and you won't wait a month to get your computer back.
Mar 07, 2009 | Gateway MX6450 Notebook
Ram upgrade
http://www.bestbuy.com/site/olspage.jsp?skuId=7333218&type=product&id=1118845304999
Above is a site showing some of the type of memory that you need. The memory type is 333 Mhz PC 2700 SoDIMM memory. Installation would cost $39 at Geek Squad.
Apr 14, 2008 | Toshiba Satellite A60 Notebook
HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop Logo
6,109 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
