Lock out codes for toyostove laser 30 - Heating & Cooling
Buffalo12980
  • 625 Answers
SOURCE: Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Posted on Nov 10, 2007
  • 3 Answers
SOURCE: toyostove laser 30 has error code EE22
EE22 is a lock out code that keeps you from continuing to try to start the heater. This code usually pops up as the result of a problem with the fuel supply (i.e. no fuel, fuel sys obstruction, clogged filter, water frozen in line, faulty igniter), but could be more serious. To clear the code the easy way, unplug heater for at least 30 minutes. While you are waiting, check your fuel tank to see if you have fuel. Then check filter to make sure the element is not clogged and that there is no air or water (or ice) in the fuel line. If you find a problem with any of these things, correct it before trying to start heater again.
For the rest email me at toyofreehelp@yahoo.com
Posted on Nov 21, 2007
Pnutgllry
  • 57 Answers
Could it have to do with the temperature sensor? If it is still coiled up on the back of your heater, it may be turning the heater off. You need to uncoil the sensor wire, and place the sensor somewhere away from the heater. One sight said atleast 8" off the ground. (I have a Laser 73 and mine is about two feet to the right and about 8 foot up on my wall as I have a lot.) You can attach it to a board if you have to, or any other item. Just put it as far away from the heat of the heater as you can so it will only be sensing the room air temp. If the line needs to be longer you can cut in stereo wire (I read this online too). Then play with the heat settings to see at what temp it is most comfortable for you. Hope this solves the problem.
Posted on Jan 05, 2009
  • 8 Answers
SOURCE: We have a p1 code?
p1 is in the testing mode the hour button will click p1 p2 and p3 depending on how many times you click the hour button or minute button . This is to manually test the burner on low , medium, or high p1 being low.To put it in this mode hold the minute and hr buttons down at the same time for 3 seconds.I unplugged the unit to reset.
Posted on Jan 04, 2010
  • 674 Answers
SOURCE: how can i get a owners manual for my toyostove
You can go to www.toyostove.com and download or print out an owner's manual. Hover over owners' manuals and when the drop down menu appears click on vented heaters. You can download owner's manuals but not service manuals.
Posted on Oct 25, 2010
How can i get a owners manual for my toyostove laser 30 ?
Oct 24, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
How do you get Rinnai energy saver (263FA) out of function lock mode
When you say "Function Lock" I am not sure what you are looking at. If it the Child Lock feature, you should be able to turn the stove off and push the Child Lock button to turn it off. Some of the error codes on Rinnai's look like tempertures,i.e. 60, 68, 11. I am not sure about the 263's but they should be just like a 556F. If you have a owners manual you can find all the codes. The Rinnai web site can help you get a manual if you don't have one.
Tom
Oct 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My Laser 30 keeps getting a ee 12 code ans shuts
Ken,
The screen for the circulating fan has lint on it. Remove it from the back top panel and wipe it off. The lint keeps the air from be able to blow over the stove and it overheats.
Good luck,
Tom
Feb 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
We have a p1 code?
Dec 20, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
OM 22 Toyostove shuts down with EE2 out of fuel code but it has fresh kerosene and a clean flame rod sensor. OM 22 is same as Laser 30 except it can run on fuel oil.
Did you check to make sure all fuel valves are open, specifically the safety valve on the back of the machine? The stem should be sticking up if this valve is open. Following that, make sure you have reset the float in the fuel feed by pushing the red button on the right side of the machine.
J
Nov 03, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
CL code
The stove is doing self cleaning I believe ;) It will show cl and then 10 down to 1 and it will restart.
Oct 28, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 30 has error code EE22
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
