Question about Kitchen Appliances - Others
The pilot light keeps turning off on one side of my Blueseal GT42 Twin Tank Deep Fryer. How do I fix this?
  • 125 Answers
SOURCE: Imperial deep fryer IFS40 pilot lights, turn on
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Posted on Feb 21, 2009
  • 30 Answers
SOURCE: burner doesn't ignite
did you check to see if the knob on the gas valve is set to on?
Posted on Mar 31, 2009
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
  • 46 Answers
SOURCE: My deep fryer keeps turning off.
do you hear a clicking noise?if so might be over load bad or the compreser
Posted on Jun 26, 2009
  • 8 Answers
SOURCE: Pilot going out when thermostat turned on
It could also be the high limit thermostat shutting the pilot lite off.
Posted on Nov 30, 2009
Deep fryer pilot light switches off automatically
First make sure that the thermocouple tube is directly in the pilot light flame. If it is, then the thermocouple is defective.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
Our staff cleaned the fryer last night and left the pilot on without filling the oil. . The fryer was with no oil and pilot on overnight. Will it lead to problems or we have to take corrective action.
If the main burners didn't light there shouldn't be a problem. If the main burners came on there could be some damage to the tank but there is no corrective action that can be taken. If damage was done it will usually leak cooking oil when filled. Was the gas valve turned to "pilot" or "on"?
Dec 12, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot light goes out when burner turned on
Replace the pilot generator. You are not getting the millivolts you need when you turn on the fryer.
Tom
May 28, 2010 | American Range AF45LP Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
IGNITION WITH PROPANE DEEP FRYER
this is a safty feature turn and hold pilot light untill lite then the gas should flow..but only after pilot is lit for 30 seconds
Nov 27, 2008 | Kitchen Appliances - Others
Vulcan Deep Fryer Need to Light Pilot
you have to hold the knob in after pilot is lit for at least one minute
Jul 09, 2008 | Vulcan EF3 Deep Fryer
Kitchen Appliances - Others Logo
52 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
