Question about HP Compaq nx6125 Notebook
No power at all.
I tried a dif pewer cord still the same. Tried to switch on with the battery out, same thing. Was working the night before, now nothing.
  • Anonymous May 15, 2009
    Charging light in front will blink yellow, then several times orange, then green. At one point my husband got it to turn on, it asked for a password, he did not know if I had one so he tried to shut it down. It started to reboot again everytime it turned off. It kept doing this until I unplugged it. It did it several more times until it wore the battery down. Now we are back to the charging lights blinking. Does not make a difference if the battery is removed or attached. Power cord has been replaced twice, by HP, I just bought a new one, but it evidentally is not the problem.
My mini 10v Dell won't charge the battery, and if I take out my battery to just run on power it won't turn on. The light that lights on if power is on blinks for a sec or two and shuts back of
take the battery out and hold the power button for like 15 seconds. then put battery baCK on and plug it in but do not try to power on. lets saee what goes? remember not to power on
Jan 31, 2013 | Dell Inspiron Mini 10v Netbook Computer
I have a Durabook that has worked Flawless up till today! It would not turn on. I tried the suggestion of unplugging the power cord, then take out the Battery, and remove the remory cover. Then I gently...
What is the exact model of the unit? How long ago was it purchased? If it is under warranty you may want to go that route, or have the unit serviced by a qualified technician in your area. If you give me your location I can assist you in finding one.
Hope this helps.
Thanks,
Lee
Jul 11, 2008 | Computers & Internet
I have a westinghouse flat screen tv model sk32h240s that has no picture but sound works. I have replaced a bad transformer and checked and replaced all the capacitors that were bad. What else should
Depends on what type of input your using. Maybe try dif cord( hdmi,component video or composite video) or try dif input on tv. Verify source has video out on dif tv or try dif source.
Jul 25, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Toshiba L25 S1216 willnot power up. Battery and cord are fine. When I push the power switch the light comes on for a ssecond and turns off and sounds like the disk starts to spin up but then dies. I...
try to switch on again and click escape reapetedly,and try to check the problem there,if this will not work,try to reset your pc and use your back up CD to reinstall again your files.
Jun 11, 2011 | Computers & Internet
When I open the doors normally everything shuts off inside, ie radio, instrument panel etc. Last night it stopped working. Everything stays running. I hadto disconnect the battery to shut it down. Still...
you will have to look for the wiring diagram to find this but try finding the relay switch had same thing happen to my 94 camaro and that's what I dif
Mar 04, 2011 | 2004 Chevrolet Suburban
I shut down my Dell Dimension E510 last night and today when I pressed the on button, the computer wont turn on - not even an orange light on the power button. I tried disconnecting all connected...
Try this procedure! click here. After checking your power supply and it is working fine, put it back again into your computer casing. Next thing to do is to check your motherboard switch (power on). Look for the manual of your motherboard and look for the power on switch. If you find it then get a screw driver and short the pin using the screw driver. Be careful not to touch the other pin! But you have to check all the computer components to determine what is exactly the cause why it's not functioning. If it's not turning on your computer while you short the power switch on that means probably your motherboard fail. Other option is, in order to troubleshoot the problem of your computer you must have an extra computer with the same model and plug all your components there one by one to determine what is exactly the problem of your computer. Then you can decide what computer parts need to be replace. Have a nice day!
Dec 23, 2010 | Dell Dimension E510 PC Desktop
My dell C840 wont power on.
well if the laptop worked till there was charge in the secondry battery its an issue with the cord or the port that connects the powercord to the laptop. ie the inlet on the laptop. check these two as well.
Mar 29, 2009 | Dell Latitude D830 Notebook
Last night my 2 wire router stoped working. The
your rooter must have a reset button on it. Considering that there was a red light on, it sounds like it is off rather than dead. There are only a couple things to try, the reset I mentioned, and the other is a power cycle. Disconnect everything the input line, the power cord and any thing else that is connected, and wait 5 minutes to reboot and connect everything.
Mar 26, 2009 | 2wire (1000-400108-001) Router
My toshiba satellite p200-140 laptop will not start up. the power button lights up but nothing else happens. it was working fine last night
My laptop had a similar problem. I left my laptop running and some time later when I went back to my laptop, it would not startup. The power light seemed to be on but the laptop would not function. I tried several things like pressing on the power key for some time without any success and also tried all sorts of alternate buttons and sequences.
I resolved the problem by first disconnecting the power cord then by removing the battery for 5 minutes. I then re-installed the battery then connected the power adapter.
As soon as I turned the power button 'ON', the laptop booted up again.
Hope this works out for you.
Regards,
Rick
Sep 28, 2008 | Computers & Internet
Pewer problem
Try to switch it on connected to an AC charger, if it switches on , then it is a battery problem. If not, it may be the AC charger, or oxide in the charger contact.
I sugggest also going to a local phone repair shop, and eventually testing a different battery and a charger.
If the battery works, replace it, if it is not the battery or the AC charger, then ask the fee for repair. Usually it is the charger or the battery.
Jul 09, 2008 | Sony Ericsson P910i Cellular Phone
HP Compaq nx6125 Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
