Question about Welding Tools
Mig welder tripping breaker
I have a Solar 2114 tote mig welder. It will trip the breaker once you hit the switch to turn on. Is this a repairable problem or not?
3 Suggested Answers
  • 3 Answers
SOURCE: mig welder tripping power supply
the breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
luis_david
  • 407 Answers
SOURCE: have solar 110
Yiu can use both innershiel and solid core wire. All you need to do is inverse the polarity for the innershield wire (gasless wire) connect the gun to the ground and ground cable to positive side.
Posted on Jan 02, 2011
MyCH115v flux core welder will not feed (wheel will not run)nor will it arc.What should I look for to be the problem?
Look at the power supply feeding the unit. Has the breaker tripped? Turn the breaker off to the outlet supplying the welder and then turn ot to the, "on" position. You can't reset the breaker from the tripped position. You need to turn it, "off" first. Look at the connectors to make sure they're plugged in properly. Check to see if there is an internal breaker that might have tripped.
Dec 06, 2014 | Welding Tools
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
Welder when turn on trips the breaker
Would you write back and clarify what steps you have taken to narrow down your search? I'd like to know if the breaker is weak and needs to be replaced. Have you plugged your welder into another receptacle to see if it trips that breaker? I don't think the trigger has to do with this problem. The symptom is that as soon as you turn the welder on, it then trips the breaker. So this tells me that the electrical cord is not shorted. When the breaker trips, is there any delay or is it instant? If there is a delay, does it sound like it does while you are welding? Do you hear that "Transformer, buzzing noise"? The trigger activates the feed motor, that alone isn't enough to trip this breaker. Which make and size welder do you have? I really am dependent on detailed information, you are my eyes and ears. Please write back with any questions or new details and I'll do my best to help, good luck.
Mar 15, 2014 | Welding Tools
When the welder is first turned on I can weld with gas for about 5 seconds. Then the breaker trips. ( i have the proper wiring and breaker). The more times I reset the breaker the shorter the weld time...
Hi:
Just make sure that if you are using an extension cable between your machine and the power outlet, this cable is at least a 12 gauge size, if you are using a 14 or 16 it's too small to handle the amps.
Other point is to check that your breaker is 20 or 30 Amp capacity.
Hope this help.
Sep 08, 2011 | Clarke Power Products Clarke 130EN...
My welder only welds for about 2 seconds then trips house breaker. i have a good dedicated 20amp breaker for the welder. what could cause this? the welder breaker in back of machine does not trip.
Is enough for this machine, but probably is not a fuse dedicate it just for this end side.
If you can turn all lights off and other items that might be in use with the fuse. If you can't then upgrade the fuse to a 30amp.
Jan 10, 2011 | Miller MilWeld MLL907263 /AutoArc XLT142...
Looking for a replacement gun for my old solar mig welder
Buy a Tweco mini gun part# 1000-1133 and an adapter part# 2500-2140, and that will solve your problem. Tweco parts are available at every Praxair location.
Get rid of the solar gun.
Dec 07, 2010 | Solar Mig Welder Welding Gun Liner Parts...
I have a brand new lincoln 180 mig welder when i hooked it up to 240 volt power it was feeding the wire just fine but when i tried to weld the wire would just stick , so i checked the power and found i was...
Have you tried it on another outlet, say at a friends' house, etc?
Reset button on the welder tripped? Double check the breakers and all connections. If it was working before, it should work now. Try some different breakers to check for good juice. Good luck!
Feb 16, 2010 | Lincoln Welding Tools
Mig welder tripping power supply
Dec 09, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Welding Tools Logo
74 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
