Altec Lansing ADA885 speaker module flashing display, no sound
Open SKy
  • 620 Answers
SOURCE: Altec Lansing ADA885 Speaker System Remote Control
Hello regginess
Hope this help you!
http://www.remotes.com/store/altec_lansing/ada885.html
Posted on Feb 15, 2008
headman333
  • 82 Answers
SOURCE: Altec Lansing Altec AVS 500
If you are using windows media player check if your player is configured to have an echo. If it is configured remove it. If it is not configured to have an echo and if you are using any soundcard have that sound card check by an expert or by your vendor and let them check it out if it is still under warranty.
Posted on Jun 25, 2008
SOURCE: Altec Lansing ada885
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
Posted on May 01, 2009
  • 378 Answers
SOURCE: no sound
check the port to which u have connected ur speakers. And also install proper driver
Posted on Aug 20, 2009
darktowernz
  • 222 Answers
SOURCE: Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Posted on Dec 06, 2009
Cable setup for Altec Lansing ADA885 system needed
Try using the internet to get the information you need
Mar 01, 2013 | Altec Lansing ADA 885 Computer Speakers
Altec lansing ada885 took a dose of 240V, burned fuse in place, replaced fuse, worked for about 2 hours, now nothing
Well is the new fuse still good or out again. if its good, then you probably fried the main board on the amplifier. These computer speakers do not handel big power serge's.
Mar 12, 2011 | Altec Lansing ADA 885 Computer Speakers
No sound "dolby digital flashes" all connections
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 13, 2011 | Audio Players & Recorders
I am having problems with my Altec Lansing ADA885 speakers. They won't play although the sound is fine and the sound comes through headsets or even the speakers to my lap top.
Do your speakers require a power source like an adapter that you forgot to plug in? make sure you plug the speakers into the correct plug on the laptop.
Jan 08, 2010 | Computers & Internet
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
I can't seem to find the drivers for my altec lansing ada885 speakers for my dell dimension 8100
i think you dont to find a driver for altec speakers, it sould be your sound card of your pc might need to have the drivers.
Nov 07, 2009 | Computers & Internet
207 people viewed this question
 Grubhead
Grubhead
