Question about U-Line Echelon Series 2075DWRRSS Refrigerator Drawer w/ Three Piece Organizing System: Stainless Ste...
Uline echelon refrigerator control panel does not work
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Oct 09, 2009 | U-Line Uline Origins Series...
My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
Oct 07, 2009 | U-Line ?chelon 2175RB-00
Uline icemaker on boat needs service..
first do a good cleaning as the manual describe.
check water supply and if still the problem, check power to cutter grid
should be 9 volts all the time
Oct 02, 2009 | U-Line Uline Origins Series...
Wiring came unplugged need wiring scematic for uline ice maker
wiring diagram is on the back of the machine. If you have clear ice maker it may be on the back of the front plate.
Jun 01, 2009 | U-Line Uline Origins Series...
Uline Icemaker has dammaged gasket door
no, you will need to replace the gasket. U-line gasket is easy to install. You can visit their website and under customer service you will see parts locator. The gasket just pulls out of the track and the new one pushes back in the track. www.u-line.com
Mar 18, 2009 | U-Line Uline Origins Series...
My uline drawer fridge quit working. Who should I call to fix it?
I would call Uline directly and allow them to recommend someone in your area that does warranty work for Uline. In this fashion, you are assured professional results and OEM parts....
Good Luck, Eric Campion
Feb 26, 2009 | U-Line 75R Refrigerator
U-Line CO2175FS-00 Echelon
Depends, if you have the later models, you can able to retighten it a the handle, it is removeable, but if you have the old version, too bad, you have to replace the whole door. You can try to call U-Line at 800-779-2547 to see which one you have.
Nov 08, 2008 | U-Line Echelon (CO2175FS01) Compact...
U-Line Echelon Series 2075DWRRSS Refrigerator Drawer w/ Three Piece Organizing System: Stainless Ste... Logo
66 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
