Question about Canon imageRUNNER iR C2880 Color Copier
Canon IRC3380 makes very light copy
After remove and reinstall Drum colour became very very light how to fix it please advice, thanks Sam
5 Suggested Answers
PATHAMPAD
  • 25 Answers
SOURCE: CANON IR3200 COPY COLOUR CHANGING IN COLOUR COPY
CLEAN OR CHANGE THE TRANSFER SHEET ASSY
Posted on Oct 31, 2009
SOURCE: Sir, I am having IR400, the copy became white
print show as jumping
Posted on Oct 05, 2010
  • 140 Answers
SOURCE: copy on canon ir400 copier
when you reset RAM the by default setting will be chang. try to get setting back.
Posted on Apr 23, 2011
  • 34 Answers
SOURCE: How to set the default copy mode on a Canon
First adjust main screen as you want if to be (ie black and white mode). Once you have your default selected go to additional functions. Go to the copy selection and with in that list there is the section to save default settings. Now when you restart machine B/W and all other setting will be default. Good Luck
Posted on Jun 25, 2011
Sir, I am having IR400, the copy became white coloured font with very dark black background, so i replaced drum & blade and then copies became normal, but very light, then i increase the density from 5...
Why did you do ccd-adj before cleaning the optics?
in copiers front door must be sheet with numbers that are factory input, do the clear all, and then set the values from paper in service mode.
May 18, 2010 | Canon imageRUNNER 400S Copier
Hello! I have a canon ImageRunner 200L. The
most likely needs a drum unit
you can try cleaning the charge roller with water. try not to touch the drum, best to remove the drum from the unit first
Jan 08, 2010 | Canon Office Equipment & Supplies
How to remove drum scretch from Canon 6045 Copier
you cannot fix a line of a drum. If the drum is causing a line on copies you have to replace it. Any light or fingerprints can cause further problems. Look online or at your local canon dealer for the drum unit.
Oct 12, 2009 | Canon NP 6050 Copier
We have a Canon PC 400 copier. When making a
Remove the toner/drum cartridge. Carefully rotate the drum, via the end with gear, to check the edges for toner spots like appear on the copies. If located on drum, GENTLY wipe off with a dry cotton ball. Reinstall cartridge. Check to see that spots are gone. If spots reappear, replace with new cartridge (drum most likely damaged)
Sep 11, 2009 | Canon Office Equipment & Supplies
My old Canon NP1215 Copier: -First copy is
most probably a change of the drum and cleaning blade is needed ,check also the fixing/fuser roller
Jul 11, 2009 | Canon Office Equipment & Supplies
Irc3380i drum
this the procedure how you removed the drum in irc3380 machine. first open the front door and remove the small cover in your right side.then open the side door.and turn the black lever to right.then push the other lever at the top of blk lever.then remove the 2 screw in both side its locate near in the blk lever in right and the other screw in your left side opposite of the other screw,then when you remove the screw pull the unit out.and you will see the square button at the top off thegray cover plastic in the rear side.push that button and pull it out.and in the rear side you will see a small blk lever to hold the itb unit.(take note not to touch the surface of the itb belt the shiny black one.then you will see the 4 color drum.unlock first before you take out the drum
May 12, 2009 | Canon Office Equipment & Supplies
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Failure to print properly
Is the machine a digital machine? If so there is a slight chance that the reason for the problem is that the mirrors are dirty under the copy glass. Remove glass and using glass cleaner on a soft cloth clean mirrors. Do not remove mirrors........
Clean copy glass and replace. If problem still there poss developer change or drum unit but most common is optic section. Also clean a **** glass in the machine. Open the door and you will notice a glass rod sticking out just above the drum unit. Remove clean and reinstall.
Hope this helps
Thanks Jason
Aug 16, 2008 | Canon Office Equipment & Supplies
Canon IRC3100 colour copier machine error code
Canon iRC-3100 Color Copier is giving Error code E-000021-0001. can anybody help me?
Aug 01, 2008 | Office Equipment & Supplies
Canon imageRUNNER iR C2880 Color Copier Logo
73 people viewed this question
old marine
old marine
