I have an itt grinnell overhead garage heater ( on natural gas ) The pilot light is going but it won't kick in ... Is it the thermo coupler or the thermostats
    New Friend:
I f you follow the thermocouple to were it connectecs to the safty valve. unscrew the thermocouple there and carefully clean the end with a pencil eracer (not sand paper) reassemble this has worked 4 me Mike
Posted on Feb 19, 2013
  • Mike Rossmad Feb 19, 2013
    i f you follow the thermocouple to were it connectecs to the safty valve. unscrew the thermocouple there and carefully clean the end with a pencil eracer (not sand paper) reassemble this has worked 4 me Mike
2 Suggested Answers
SOURCE: pro comm natural gas heater, pilot keeps going out
The problem is likely to be either the thermal-couple (easily replaced) or a clogged gas orrifice. The clogged orrifice would require a bit more know-how then the thermal-couple and with gas appliances it would be best to hire someone who knows what they are doing.
Posted on Mar 21, 2009
How do I bypass my hayward h250 millivolt pilot light
cannot check pilot generator, then make sure no cobwebs in tube or assemby if dirty clean if clean replace thermo coupler
Jun 25, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Replace thermcoupler patio heater
I would first check that the thermo coupler is sitting inside the flame when you ignite the pilot light.
Replacing the thermo coupler can be a real hassle.
Mar 10, 2012 | Next Generation Power Engineering Garden...
Cant get the pilot light to stay on, I have changed the pilot assembly
change the thermo coupler it tells the unit when the pilot is lit hope this helps bob
Apr 27, 2011 | Reliance Natural Gas Water Heater Control
Pilot won't stay lit I have changed the thermo coupler
Make sure the thermocouple is in the pilot flame,if it does not stay on after that,replace the regulator.
Nov 16, 2009 | Cozy Enclosed Front Console Heater 70,000...
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
How do i install a thermal coupler for forced air heater gas
Thermo coupler is held in place with a clamp bracket at the pilot end and a small brass line nut on the other end going into the gas valve.The pilot flame must surround the sensing bu or wrap itself around it Press the pilot button for a few seconds and fire up the pilot flame. Wait a few more minutes and turn the gas vale on for the main burners. If it fires, your set.Good Luck,Ned
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
487 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
