Question about Williams 2509612 Ceramic Mid-Size Heater
Heatilator Pilot Issue
I have a Heatilator Novus series gas fireplace. The pilot seems to have gotten rather high over the years. In the manual it shows a pilot adjustment area. I looked and found a cap screw. Is this a screw cover or is this the adjustment screw. The flame on pilot is a 1" blue and yellow flame.
  • Williams Master
  • 8,220 Answers
Any pilot adjustment would be under a large screw with a flat blade slot in it. There would be a smalled flat blade screw under it. Warning: Too small of a flame and your safety device won't work.
Posted on Feb 09, 2009
How to replace a pilot assembly on a fireplace
Monesson has all of these on their website. usually when someone believes they need to replace a pilot assembly the actual problem is a maintenance issue. Clear the air-holes at the base of the pilot tube with a vacuum cleaner.
Sep 04, 2014 | Monessen Wdv600ntsc Serenade Series 60inch...
Have a heatilator direct vent GC300ST 15+yrs pilot woont stay lit think I need a thermoplie where can I find ? thk you
You probably need a thermocouple. Any local fire log sales store typically has a thermocouple in stock. If your system has a thermopile as well and is 15+ years old, I'd suggest getting anew pilot assembly and installing it. This way all the parts are new and you won't have to replace another part in 6 months.
Feb 25, 2014 | Heatilator Home
Gas fireplace won't light
Your fireplace does have a pilot. It is either millivolt, where you manually light the pilot and use a remote or wall switch to light the logs
or is IPI where it still has a pilot light but the reote or wall switch lights the pilot first then the logs. The second version has a non-standing pilot. In either case, it sounds like a pilot assembly issue. When you "throw the switch", do you hear clicking inside the fireplace? If so and it does not light, you may have a pilot assembly issue. If there is no sound at all, then you may have a bigger issue with the control module. The only sure way to know which is the culprit is to have a certified technician come oput and examine your fireplace.
Feb 02, 2014 | White Mountain Hearth Empire Tahoe 36...
Pilot will not stat lite on gas fireplace
You may have one of two typical issues:
1. the thermocouple is bad and needs replaced
2. the control module may be bad and need replaced.
A certified and trained service technician can come out and diagnose the issue within a few minutes. There are numerous little tests that can be done to determine and isolate the issue.
Nov 15, 2013 | Heatilator Home
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a Heatilator IDV4833ILT propane fireplace, the pilot will light but not the main flame Thank you
there might be air bubble in the gas valve/ might need to change gas valve
Jan 18, 2011 | Heating & Cooling
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Dec 08, 2009 | Heating & Cooling
Help troubleshooting an FMI GL-850E Gas Fireplace
It sounds like the Ignition Control Module went out, as I've heard the vibrating noise you speak of just before the module "dies." You most likely have the gray Robertshaw control module box located under the fireplace connecting the power to the gas valve. You will need to have a Certified Gas Fireplace Specialist look into this issue and replace, if necessary.
Dec 07, 2009 | Heating & Cooling
Heatilator gas fireplace orphis
Hi follow the gas line from the outlet of the gas valve to the burner injector is there you will have to remove the burner and change pilot injector aswell
Apr 22, 2009 | Stoves 1000DFDL Dual Fuel (Electric and...
Williams 2509612 Ceramic Mid-Size Heater Logo
2,090 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
