Question about Danby DWC2121BLS Wine Cooler
One side on my wine cooler stopped working
My wine cooler is working on one side only I vaccumed the back vents but still only one side is running
4 Suggested Answers
  • 1122 Answers
SOURCE: WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Posted on Nov 11, 2008
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
supernova278
  • 1932 Answers
SOURCE: dual zone wine cooler left
Please can you give the model number of your Danby refrigerator
Thank You
Posted on Oct 14, 2010
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Vinotemp wine cooler just stop working.
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Apr 28, 2014 | VinoTemp (VT60GNV) Wine Cooler
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Unit has been operating in a wine closet and just stopped working it there anything I should check or clean? swaney167@aol.com
does the 'closet' have any ventilation? if not the unit could have overheated and shut down or , worse, burned up the motor. any 'electric smell to it? under the unit, should be a fan, it that stopped it will not cool. look for lint build up under the unit or around any air vents. How old is the wine cooler? can you get any info from the Wine cooler's mfg web site? www.danby.com/products/wine__beverages -
Dec 26, 2010 | Danby DWC440 Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
COOLER IS GETTING POER BUT NOT COOLING. TEMPERATURE CONSTANTLY SHOWING 72 DEGREES.PLEASE SUGGEST TROUBLE SHOOTING. #K0700305460011335 MODEL: OW0912H6H
Check the lint trap behind your cooler to make sure it isn't clogged... I had the same problem and after vaccuming the lint trap, my cooler started cooling again
Feb 06, 2010 | Oster 12-Bottle Wine Cellar - Black
Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Dec 31, 2009 | Vintage Keeper Koolspace Wine Cellar
Danby DWC2121BLS Wine Cooler Logo
32 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
