Question about Grohe Classic Kitchen/Bar Faucet 31.057.000...
My Grohe Kitchen Fawcett lost water pressure, is their a manual online available?
  • Anonymous Mar 16, 2009
    Same peoblem, low pressure, low flow!!!
  • Anonymous Apr 29, 2009
    grohe kitchen faucet has almost completely lost its water pressure while all other water outlets function properly
  • 50 Answers
Make sure you check the strainer that unscrews from the spout. SOmetimes these clog from sediment. ALso check the supply valves to the faucet (sometimes there is sediment in these--opening and closing helps) you may have to remove the cartridge(s) depending on you model number. You can probably download the manual at
Posted on Jan 04, 2009
I have a single handle Grohe kitchen faucet with very low water pressure. All other areas of the home are fine.
Try this site
Also alot of videos on specific Grohe faucets on youtube. Not sure your model. Take a look.
Hope this helps some.
Jan 26, 2017 | Grohe Plumbing
Low water pressure in my grohe bridgeford kitchen faucet what could be the problem
The first thing to check is the areator at the end of the spout...
They often plug with dirt and drop the water pressure...
Take that off and check out the water with it off...
Then if it is still low then it is dirt trapped internally in the faucet...
Sep 26, 2010 | Grohe Classic Kitchen/Bar Faucet ...
Lack of Water Pressure
If you have the spray head type, I had the same problem...called Grohe. They said to remover the pressure regulator. Take off the spray head, and just inside the end where the water comes in, you will see a white plastice thingy. Remove it. They said you can do it with needle nose pliers, but I had to pry it our with a tiny screwdriver. It came out in pieces, but once out, the water pressure is GREAT!
Mar 07, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Low hot water pressure on Grohe LadyLux.
1. If by replacing the flexible hose you mean the hose for the pull-out portion - you have more than likely kinked or bent the supply line to the hot (left) side of the faucet.
a) If this supply is braided, then simply shutting of the water supply, removing the braided line and either replacing or attempting to straighten it out will be your best bet.
b) If the supply is copper, you will have to cut the line cleanly and carefully. you will then most likely need a 1/4" or 3/8" compression/quickconnect BY 1/2" IP fitting to complete your repair.
2. Other possibilities include:
a) Failure inside the faucet body which will most likely be warrantied by Grohe if you push them hard enough.
b) A problem at your hot water tank, most likely the outlet side and *perhaps* you hadn't noticed the problem elsewhere.
c) The hot valve failing to reopen fully despite all appearances; applies if you turned off the water under the sink for your repair.
Aug 05, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
May 21, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Water pressure very low
Sounds like the cartridge needs to be cleaned or replaced. May be clogged or faulty. This requires turning off water under the sink and pretty much taking the faucet apart.
May 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
American Standard kitchen fawcett
It could be air if you recently had the water off at the main and let the pipes drain, but this would go away after a short while. It is most likely either a feed line from the wall to the faucet flexing when the pressure and hitting something under the sink or a water line in the wall that may have not been strapped properly to the stud when installed. They bounce around sometimes if not secured. Hopefully the feed line as the second is a bit more work to correct.
Good Luck
Nov 29, 2008 | Plumbing
Grohe Classic Kitchen/Bar Faucet  31.057.000... Logo
617 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
