NEW Yellow Ink Cartridge Does NOt Print!!
I just installed all 4 new cartridges in my HP1200C Desk Jet printer and when I run an ''inktest'' doc the Yellow DOES NOT PRINT!!
Is there some maintenance that I should do??
ANY and ALL HELP will be greatly appreciated
  • poshsop Jan 04, 2009
    GREAT SUGGESTION!!
    I'll give it a try and follow-up with (I HOPE) a successful feedback note.
    Don in San Jose CA
  • 16 Answers
The following is good advise I found here:
A clogged print head on your inkjet printer is not a fine thing. Over time (especially when there's long periods of no printer use) the many tiny holes that make up a modern inkjet printer's head can become clogged with dried ink.
Most printers today have some sort of cleaning routine where either you instruct the printer to go through a cleaning cycle via a program on your computer or you press a squence of buttons on the printer itself to begin the process. A number of these cleanings, in succession, will usually take care of a clogged head--but not always. I recently found my year and a half old Epson Stylus Color 600 unable to print coherently using black ink and no amount of standard cleaning-cycle runthroughs would fix the problem.
On some inkjet printers (HP's for instance) the ink cartridge contains the print head, so changing the cartridge gives you a new, unclogged printhead. My Epson's print head is part of the printer itself, and can only be replaced by a service technician, and the cost is usually very close to the price of the printer itself. I had to come up with something better than that, so I began searching the web to see what people in similar predicaments had done. I found that I my problem was not unique and there were some rather successful remedies floating around.
I discovered that isopropyl alcohol (I bought a bottle of 91% alcohol at the drugstore for ~$3) is a great solvent for this sort of dried ink. There were those that recommended that I take an old, discarded ink jet cartridge, open it, clean it out with the alcohol, fill it back up with alcohol, reseal it, and place it in the printer for a few runs through the printer's self-cleaning method. This proved to be a rather messy endeavor indeed, so I followed a bit of less-agressive advice.
I simply removed the black print cartridge from the printer and dropped 7-10 drops of alcohol down in the ink-recepticle area where the ink cartridge normally sits (there should be a little hole down in there where the ink actually flows from the cartridge into the head), replaced the ink cartridge, and ran a few sessions of the printers head-cleaning routine. It took quite a few cleaning sessions (probably 15-20) with a few pages of text prints thrown in there just to try and move some ink, before it cleared up.
It actually had to sit overnight, with the last few cleanings done the next morning, before all was well--but well it is. Everything works perfectly now, and I don't have to go out and buy a new printer.
To avoid such blockages, it's a good idea to print something, both in color and black&white (if you've got a color printer), once a week or so just to keep things moving. But if you do end up cursed with a blocked print head--this method should take care of you.
Posted on Jan 04, 2009
Yellow ink doesn't print from the cartridge.
Try to change ink jet cartridge with a new one from hp and then blow off the contacts with compressed air. Make sure the tape is removed from the nozzles of the ink jet cartridge before installation.
Good luck on this repair.
Feb 09, 2011 | HP DeskJet 970cse InkJet Printer
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Installed new yellow print cartridge for HP printer, prompts to install new cartridge but my ink level says full
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
I have a hp desk jet model 710c printer. I have cleaned and aligned the printer. The color red does not print. A test print will not print RED. Do you have any suggestions on what to try?
simple.the ink in the colour cartridge is over.usually pink and yellow mix to form red any of the 1 colour is over.just get your cartridge refilled or buy a new cartridge.the printer is absolutely perfect.
thanks.
Nov 14, 2008 | HP Office Equipment & Supplies
Installing new ink cartridges
Be sure you have snap the ink cartridge tight, and check the expiration date of the ink cartridge.
Nov 12, 2008 | Dell Office Equipment & Supplies
Hp deskjet 5650 inkjet printer
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 22, 2007 | HP DeskJet 5650 InkJet Printer
Yellow won't print with old or new cartridge
Some ink jets are differant. Some have an Ink jet cartridge system that has the print head on the cartridge itself. Others use a seperate print head. When you pull out the ink cartridge is there another small unit below the cartridge that you can pull out? If so that is the print head and you will need to replace it. Also make sure that you have taken off the tape off of the air pilot hole on the ink cartridge so it can work properly. www.tonerovernight.com
Mar 16, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
952 people viewed this question
jasbo
jasbo
