Question about Vacuums
Broken Riccar 4810 wand
Hello-
My 'Riccar 4810 Fast Track' vacuume cleaner wand just broke. It's the end piece of the 3 part nesting tubes, the piece that fit's into the base of the vaccume it self. Can you please tell me where I can buy just that piece, with out having to purchase an entire new hose set?
Thank you!
4 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: Hoover Wind tunnel supreme, loss of suction
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40600&thid=562967
posted by bazballfan on May 01, 2008
Hello, I purchased two of these models in late 2007 and after changing the bags on each of them I have little to no suction with the vacuum. The hose is fine and I have taken them apart and there is no obstruction in the hose or in the base.
These worked so well and now they don't do anything. The bag isn't filling much and the simplest things can’t be vacuumed up
Please help me to fix this
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U5450-900 Windtunnel Supreme Vacuum
Sorry you are having a problem, it sounds lie you have done almost everything, but just in review it could be some of these problems:
Belt change – every 4 to 6 months
Are the brushes in good shape
Where does your suction drop off
Is the bottom plate securely on the bottom
Are there any gaskets that are broken or leaking
Is the bag installed securely
Did you check for any clogs or obstructions
Is the filter clean
Feel free to contact your local vac dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on May 01, 2008
SOURCE: How to replace just the Kirby 210097 Hose End For
If you just grab it where it swivels and pull with a slight bending motion the plastic "bayonet" section on the end of the hose will pull out of the plastic housing that attaches to the vacuum. Don't pull on the corrugated hose section or you will ruin the whole assembly.
Posted on Jan 31, 2010
VacuumRepair
  • 438 Answers
SOURCE: I bought a replacement brushroll because the one
Greetings from GoVacuum,
Make sure the vacuum is NOT plugged in. In order to replace the roller brush, you'll need to unscrew the 6 screws on the bottom plate of the vacuum cleaner. Oreck uses a Phillips Head screw, so you'll need to get a Phillips head screw driver to replace the brush.
After removing the screws from the bottom plate, simply pull up on the plate by putting your fingers into the open area where the existing brush is located. After the bottom plate has been removed you will have access to the roller brush and belt.
You can now just grab the roller brush and pull straight up on it. It's beneficial to change the belt of the vacuum when you're replacing the roller brush anyways. There is a spare belt on the actual bottom plate of all Oreck XL vacuums.
You'll notice that the new roller brush has two black square plastic caps on both sides of the roller brush. You can look on the outside of this black cap, and you'll see the words OLD and NEW. Rotate the NEW side so it's facing upwards, and the OLD side is the side that's down inside the vacuum cleaner, make sure that both sides have the NEW side facing upwards. You'll need to wrap the belt around the silver pin in the back of the vacuum on one side, and through the roller brush's metal pulley on the other side. The just stretch the belt with the brush inside of it, and place the black plastic parts back into the vacuum cleaner.
Congratulations, you've now just replaced the roller brush in your Oreck!
Please feel free to email me if you have any questions on how to complete this repair, or just request a clarification through this Fixya page. My email address is chris.jones@govacuum.com.
If this repair solution was helpful, please be sure to rate this repair as helpful by clicking the 4 Thumbs Up icons in the top right hand corner of this repair solution.
Be sure to check out http://www.govacuum.com for all Oreck vacuum cleaner parts and supplies!
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
SOURCE: The clip that holds the EL5 powerhead to the wand has broken (again). How does one fix this?
i found this part online- search for part # via an exploded parts diagram of your specific unit (via google)
i ordered 5 of them because it always breaks or pops out.
this is a nice machine with crappy parts.
sorry :(
Posted on Nov 01, 2010
How do i replace the fan on a riccar rsl3 vacuum cleaner?
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
RICCAR 220 CANISTER VACCUM CLEANER POWER HEAD FALLS OFF OF WAND.
There is a little tab that releases when you push the pedal. The tab is probably worn and needs to be replaced. This repair is not hard to do when you know how but can be difficult if you've never done it. You can get the parts and advise from your local Riccar dealer
Feb 15, 2015 | Riccar Vacuums
Not picking up. No suction
Make sure good suction at the end of hose and no clogs in tube hose goes into at bottom of vacuum. If good make sure belt is new and brush roll spins fast when lowered onto carpet. It may need clutch adjusted or rubber pad replaced.
Oct 06, 2013 | Riccar 8955 Upright Vacuum
Broken handle riccar radiance
Take the broken part to your Riccar dealer. The newer models have an upgraded more durable handle. You can get the upgrade for an older model.
Mar 25, 2013 | Riccar Radiance Vacuum Cleaner HEPA Filter...
I put the wand back inside of the tube and clicked the handle back onto the vacuum. Now the wand is poking down the bottom of the back of the vacuum. It's pushing down the black curved piece at the...
The black curved piece you mention is part of the changeover valve mechanism, which automatically diverts suction from the cleaner head to the hose when you remove the wand from the cleaner. The position you've described it in - open, with the base of the wand poking through - is normal when the wand is fitted on the machine, and is nothing to worry about.
If you have any further concerns, please get in touch with us directly so one of our experts can provide the assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Aug 05, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Where is the reset button located?
The reset buttons on the Riccar vacuum cleaners are located at the bottom of the vacuum cleaner in the back, underneath of where the wand sits on the vacuum cleaner.
Here's a picture of a Riccar 8925 which replaced your 8850 a few years ago, but the reset switch will be in the same exact location on all Riccar uprights;
Here's a closer look of the reset switch;
I hope that I was able to answer your question. You can avoid the reset switch flipping in the first place by always ensuring that you change the bags frequently and when full, as well as the motor filter that sits underneath of the bag. Also keeping the vacuum from clogging will prevent this.
If you found this repair solution helpful to you, may you please click the 4 Thumbs Up Icons in the top right hand corner to help me out here on Fixya? I really do appreciate it, thank you so much.
Chris
GoVacuum
Jan 15, 2010 | Riccar 8850 Vacuum
The wand is hard to pull up
The wand on this machine get lots of tiny dirt and fine dust caught in the sliding tube that fits in the hose. You will need to take the hose at its cuff end where it meets the wand and press the two tabs to release the wand out, then take some spay cleaner of any kind and wipe down the wand tube. This should make it easy to slide in and out of the hose. Now just put it back together.
Dec 10, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The roller brush will not stay on-& the cord rewind is stuck on
There is a reset on the power head, does the wand fit tight in the neck of the power head, if not you may have a problem there, either the wand or the neck. If the lever is stuck on, then it is jammed or broke, maybe a spring is out of place, in any event the canister will have to be taken apart to see what the problem is.
Feb 19, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
50 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
