Question about Samsung HLN617W 61" Rear Projection HDTV
Projection Mirror Broken
I own a Toshiba 52hm84, which I purchased over three years ago. The TV was damaged by movers and as you can imagine it has been an uphill battle to get them to cover the repair. I was advised by a Best Buy Technician the mirror is cracked and needs replacing. Where can I purchase the projection mirror and are their instructions available to replace it. I have not been able to enjoy the TV for a couple of months and have been looking all around for answers. Can you help? I appreciate your response in advance.
Thanks,
Boston
    Genius:
  • 2,920 Answers
You should be able to go to a used tv shop give them the model of the tv and have them order a new one. they are not hard to put back in place..call any tv repair shop and ask them to order it for you
Posted on Jan 04, 2009
I have a sony 50WE655 50" rear projection
i think yours projection t.v mirror are damage
Feb 05, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tip
Toshiba 52HM84 Manual Download
Toshiba 52HM84 DLP Projection HDTV Manual Download
Have you misplaced your Toshiba 52HM84 DLP Projection HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 52HM84 DLP Projection HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 52HM84 DLP Projection HDTV instructions.
I hope that helps.
_______________________________________________
Toshiba 52HM84 Service Manual Download
on May 14, 2010 | Televison & Video
Tip
Toshiba 52HM84 DLP Projection HDTV Service Manual Download
Have you misplaced your Toshiba 52HM84 DLP Projection HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 52HM84 DLP Projection HDTV Service Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 52HM84 DLP Projection HDTV Service instructions.
I hope that helps.
on May 13, 2010 | Televison & Video
When I turn on the TV the sound comes on but there is no picture. It turns off/on automatically several times then the green and red lights blink with no sound.
this is common problem for rear projection TV set's you have to replace the BULB after a approx. time of 2 years I found the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=52HM84
Sep 17, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
My toshiba tv 52hm84 is turning off by itself how do i fix it. i replaced the bulb. but it still turns off about 15 to 20 minutes after its on. the picture will start cracking before it turns off
you have not corrected the problem by replacing the bulb you have to probe more deeper into the tv.check your regulator in the power supply it is a ic maybe it is damaged also check to horizontal output transisitor Q405 IT CAN BE DAMAGE.Good luck.
Feb 21, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
I hope that helps.
on May 13, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
I hope that helps.
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung HLN617W 61" Rear Projection HDTV Logo
169 people viewed this question
Henry  Thomas
Henry Thomas
