Question about Danze Plumbing
Fixing a danze d454557 kitchen faucet leak - Danze Plumbing
meBNme
  • 334 Answers
SOURCE: Kitchen Faucet Leak
The stem and washers inside the faucet need to be replaced.
If you Do it yourself the parts typically will cost you less than 20 bucks.
Most plumbers will charge 75 to 100 for this relatively simple Job.
You can order parts directly from the manufacturer, or from a local plumbing supply house.
The faucet may still be under warranty and the parts would be free. Here is ther number for Price pfister.
1-800-PFAUCET (1-800-732-8238)
Posted on Aug 24, 2009
Testimonial: "As you suggested, the faucet was under warranty and Price Pfister is sending me some parts at no costs. Hopefully, the parts will resolve the issue."
  • 30 Answers
SOURCE: Looking for parts breakdown picture for DANZE NSF
NSF 61(-9) is a standard rather than the model number (it's often very difficult to identify the model number. If you are able to find the model number, the link attached has all the technical specs for Danze products (even discontinued ones). http://www.danze.com/tech_specs.asp
Otherwise, I suggest browsing their faucet section until you find yours.
Good luck.
Posted on Sep 18, 2009
  • 127 Answers
SOURCE: danze kitchen faucet spout difficult to move from
o-rings in the spout need to be greased or replaced...use silicon grease if you are greasing them....not petroleum based product.
Posted on Oct 18, 2009
SOURCE: REcently installed Danze Ashburyee kitchen faucet
Disassembled hose and realized all I needed to do was tighten the brass coupling to the hose. Problem is fixed.
Posted on Jan 31, 2010
  • 152 Answers
SOURCE: my danze kitchen faucet is loose and wobbly
You can see the installation manual here:
http://www.ajmadison.com/ajmadison/itemdocs/D403412-chrome_manual[1].pdf
Hope this helps! Remember to rate me, thanks.
Posted on May 26, 2010
How do i remove handle from danze kitchen faucet?
Google Danze kitchen faucet diagrams and it shows the intricate parts of different faucets
May 03, 2014 | Danze Plumbing
Danze kitchen faucet no:FS1B4034NP. It leaks around the spout when i turn the water on. I have received a new spout seal kit but no instructions on how to install
you should be able to unscrew collar,the top piece just before it goes into base,I use a piece of cardboard in the jaws of channel lock pliers to keep from tearing up chrome
Jan 28, 2011 | Danze Plumbing
We do not have book on the kitchen faucet which was purchased by a previous owner. Looks just like the Danze D306357BN. It is leaking from the first joint above the base. A plumber could only tell us that...
there are several O-rings inside the spout assembly. 3 that I know of from memory.<br /> <br /> here is a link to the PDF parts breakdown to show your plumber. also that faucet is for the bathroom sink.<br /> <a href="http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN">http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN</a><br /> the link to the PDF is at the bottom of the page "illistrated parts list" <br /> <br /> here is the link to the kitchen faucet. just click on the "illistrated parts list" to get the breakdown.<br /> <a href="http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357">http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357</a><br /> <br /> if neither one of these is your faucet, just continue looking through till you find yours, and call a different plumber.<br /> <br /> hope that helps<br />
Aug 31, 2010 | Danze Plumbing
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
Don't know what side allen key to use on danze D456513SS to fix a leak?
Buy a cobination set of allen keys usually between 1mm to 10mm and use the one that fits
Jun 17, 2009 | Danze D403412 Melrose Single Handle...
My Danze Anu Kitchen Faucet
Sounds like you have hard water.  You need to change the inside of the facet.  before doing anything make sure you CAN get the parts for you facet.   Danze are not very expencive you might just get a new facet.  If this is a hard water problem you might want to buy a moen facet with a life time warrinty.  More money but free replacement parts.
Apr 04, 2009 | Plumbing
Plumbing Logo
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
