Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3t washer not working properly
After the wash cylce the washer goes into a Suds mode then we get a F02 display, we have checked th drain hose, the elec connections, replaced the pump, cleaned the drain pump filter. We have had a local appliance dealer out 3 times now and after $175 bill washer still not working properly. It has been a great maching for the past 6 years this is the first problem we have very had. We have cleaned & Cleaned and replaced pump, and still does same. The washer Will not run a complete washing cycle.
  • 1 more comment
  • stelli43 Jan 07, 2009
    Same identical problem recurring over and over. Such a huge disappointment for the Kenmore brands & it's only 4 years old and out of warranty.
  • rmcclellanjr Jan 08, 2009
    Your free solutions doesn't work very well. You should not advertise free, false advertising. Maybe we should notify the F.T.C. since your free help gets not response.
  • Anonymous Feb 03, 2009
    he3t front loading washer will not spin out.
  • 640 Answers
Ok lets see here im onthejob,,i take it that cycle stops with suds..ok first are we using he or low sudsing detergent,,,next when you clean pump filter did you check pump wires for defectives,,,try and bleach unit out to get rid of slugg...also check connection to pressure switch,,and ccu...keep me posted..onthejob
Posted on Jan 17, 2009
F02 error on Elite HE3t washer even after cleaning. Loud Clicking noise coming from pump. What do I need to Do?
F02 means Long Drain Error or Drain time longer than 8 minutes.
SUDS is typically a secondary error.
This is indicative of a drain pump problem and/or clog in the drain line.
You should check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click HERE for step-by-step instructions.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks
Oct 05, 2011 | Kenmore Elite 45986 Front Load Washer
My Kenmore HE 3 washer keeps stopping mid cycle and beeping showing an F 02 message. We cleaned out the hose but it is still doing it. If I unplug it and do the spin/drain cycle again it will work...
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Kenmore HE3T Washer
HE3T WILL NOT GO INTO SPIN PUMP TAKES A LONG TIME KEEPS SHOWING A CODE OF F02
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Kenmore HE3T Washer
The F02 keeps flashing M#110.42832 CSM#1004028 pls help
Kevin
Feb 09, 2011 | Kenmore HE3T Washer
I have the Kenmore Elite HE3t. It was flashing F02, I have found solutions to get washer to stop beeping and flashing code. husband checked pump and put back together. Tried to wash a load of clothes and...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 14, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer he3t- beeping F02
"F/02"
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 13, 2010 | Kenmore Washing Machines
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
After f02 code came up ran a test and get c00 andhttp://www.fixya
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 27, 2009 | Kenmore Washing Machines
HE3t front loading washer-F2 alarm
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Jul 04, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
On HE3T wash stops in middle of cylce and flashes F2
"F02" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Most commonly, your drain pump has something clogged in it causing the drain flow to be obstructed. I would begin by checking the drain pump reservoir. I provided a follow-on link with the advice I gave you that explains how to do this. If you have any questions along the way, please let me know. I hope this helps you.
May 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
190 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
