Question about Samsung SyncMaster 2233SW Monitor
Samsung 2233SW menu buttons stuck. Menu constantly rotates through choices. Can not stop this from running
Menu constantly cycles through all choices. Can not be stopped. Causes screen to flutter as menu goes through brightness selections over and over
  • 225 Answers
SOURCE: The brightness menu screen is stuck on!
Please try to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu from your screen. regards
Posted on May 28, 2009
Mauglis
  • 134 Answers
SOURCE: my button menu in my monitor is locked (model
Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment lock function.
Posted on Apr 26, 2009
shibipg542
  • 63 Answers
SOURCE: Samsung Monitor 720N
check the resolution of the system make it as 600*800.
Posted on May 20, 2009
prashanthcl
  • 460 Answers
SOURCE: samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Posted on Nov 13, 2009
  • 1768 Answers
SOURCE: Samsung flat panel monitor brightness indicator problem
This is a firmware issue.
The system is telling you that the monitor is having an issue with the brightness and is not able to regulate it by it's internal program.
It seems that this device is needing electronic service.
Hitting the menu buttons will not remedy this issue. You will need a service tech to diagnose the problem.
Posted on Dec 03, 2009
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers ยท Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
How do I turn off the menu for the monitor?
Just press "menu" again and it will turn off.
Oct 24, 2014 | Samsung SyncMaster 2233SW Monitor
How to fix Syncmaster 2494hs touch menu problem?
Have you tried doing a factory reset on the monitor? If the problem persists, then it could be an electronics fault or a stuck button.
May 11, 2014 | Samsung Computers & Internet
Samsung syncmaster 2233sw driver for windows 8
I would make sure my video drivers adapters are up to date. Use windows update to automatically set the proper driver to the display and to your video adapter.
Mar 24, 2014 | Samsung SyncMaster 2333SW 23" LCD Monitor
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
My Samsung Messenger 2 was dropped into a glass of pepsi and has a few serious problems as a result. The menu screens keep advancing on their own, cycling through each of the choices and moving on......
Unfortunately you have dropped your phone into a weak carbonic acid solution, it's almost the worst thing possible. The residues will continue to corrode the insides of your phone so there is no way to save it now as the physical damage is well under way.
If the Pepsi was the regular type and loaded with sugar, then those deposits will have just made matters even worse.
Sep 21, 2010 | Samsung Cell Phones
Format error on my nw-505
be sure to format using the MENU mode on the unit and ADVANCE MENU then FORMAT Press and hold the search/menu button for half a second in stop mode. The menu screen is displayed. Rotate the shuttle switch to select "Advanced Menu" > and press the play/stop button to confirm. Rotate the shuttle switch to select "Format" and press the play/stop button to confirm. Rotate the shuttle switch to select "OK" and press the play/stop button to confirm. "Formatting..." blinks and start formatting. When formatting is complete "complete" is displayed.
This is how i get rid of the problem "Format Error".
May 11, 2009 | Audio Players & Recorders
My button menu in my monitor is locked (model 2233sw) how do I unlock it . mavis
Apr 26, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Menu rotates
Had the same problem with the Mitsubishi ws 48511 model. A solution posted in FixYa worked great and might be worth trying as they have very similar electronics and panels -- did you check to make sure that one of the front panel buttons isn't stuck in the depressed postition? For me, the device menu kept cycling and remote wouldn't work. Sure enough, the button was stuck pushed in. It was hard to even notice, but took little effort to get it free. Good luck.
Nov 13, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Samsung SyncMaster 2233SW Monitor Logo
206 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
