Question about Sony SPP-S2730S Phone
I lost my portable phone and cannot program the date and time on
The base   its a sony quadra station 2.4
  • richardcox12 Jan 04, 2009
    my e mail is richardcox1234@aol.com
  • 43 Answers
You need to pick up a new phone handset.
Problems registering and I can help.
AL
Posted on Apr 26, 2009
Panasonic KX-TCD25AX cordless phone. Why can't it find the base station?
several reasons
too far away from the base station
too much interference between the phone and the base station ( buildings, iron sheeting etc)
the phone is not programmed into the base station memory-- re do the system program where the base station recognizes each phone and sets it's number for identification
May 14, 2015 | Panasonic Lands Phones
Change the screen
Press "Program" and then the "0" button on the dialer to enter the program menu. Enter the date using the following format: year, month, day and weekday (Monday equals "1," Tuesday equals "2," and so on). As an example, Tuesday, Nov. 13, 2010 at 8:00 a.m. uses the following string of numbers: 101133 1 0900 2.Press the "Store" button on the phone base. Press the "Program" button on the base. Hang up the phone receiver
Nov 28, 2013 | Panasonic KX-T7731 Corded Phone
One station just reads 101, does not read the time or date as I'd like it to. How do I program that to read the time and date?
Without doing anything else, press the * button one or 2 times until what you want shows up on the display. Depending on the system, it toggles between extension, time and day, and date.
Aug 30, 2010 | Panasonic KX-T7731 Corded Phone
Base phone not charging even when phone left in phone base overninght
take a volt meter and check the contacts the phone sits on in the base station, there should be around 5 volts DC there, if there is I would replace the batteries in the phone, if there is no voltage at the charging contacts in the base then the base station is defective, another quick way to determine the cause of the problem is take the phone out of the base station and put it into one of the other phones chargers, then if the phone does charge up the base station charger is defective, u will need to replace the phone or not use the base station for charging. these are not repaired except under factory warranty.
Feb 23, 2010 | Panasonic KX-TG1033S Cordless Phone
I have the swatch cordless II phone with base station however I have lost the instruction manual for the base station and therefore cannot register the handset with the base station. Has anyone got a...
To register a handset with Cordless 2 base: Keep pressing call button [loudspeaker icon] on base for 5sec. then press [right pointing arrow in a diamond] twice. Then 9 0 1 then the system PIN if required. Choose internal number 1 to 6 for this handset and then the designation of the base station A=2, B=5, C=8, D=0, followed by [right pointing arrow in a diamond].
Hope that helps!
Jan 17, 2010 | Lands Phones
AVAYA MERLIN ETR-18D TELEPHONE
The following is from here.
IF you have a Lenend or Magix system. IF SO, you will have a VERY LARGE display phone, ususally at the receptionist station. It will be either a MLX20L or a 4424LD+. If so....
Changing the time on a Avaya Merlin Magix system is accomplished from the system programming console. The date is change separately from the time.
Changing the date:
1. Press Menu
2. Press System Program
3. Press Exit or Start
4. Press System
5. Press Date
6. Enter the date as: mmddyy where mm = month, dd = day, yy = year
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
Changing the time:
1. Press Menu
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
Aug 27, 2008 | Avaya MLX 5D Corded Phone
Vtech cordless phone appears to be mute
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
Aug 24, 2008 | Vtech 9009111 Cordless Phone
Siemens cordless phone gig set 4000
Hi James, Here is a link to the instructions below to download the Siemens Gigaset Manual for free or for Siemens repair services. However, on the 4000 model you can easily set the time by pushing menu, scroll down to base settings push OK, push OK again for clock, then scroll down to TIME, and push OK and make your changes. Also, you can change the date, as you saw in the menu. If your using a 4200 handset, the menu is slightly different, but similar. And if you get caller id, the phone will automatically read the system date and time from the phone company so you never have to set your time again. Here is the link for the manual, you may need to go to a different manual depending on your base station model. Good Luck, CG http://www.barclayent.com/manuals/Gigaset%204000%20Quick%20Start.pdf
Feb 17, 2008 | Lands Phones
Time and Date wrong on caller ID
I would check with your service provider. It maybe just a programming error in the switch from there.
Jan 31, 2008 | Uniden TRU8885-2 Cordless Phone
Sony SPP-S2730S Phone Logo
75 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
