Question about Craftsman Garden
Craftman lt1500 disengage the reverse blade cut off switch
5 Suggested Answers
  • 109 Answers
SOURCE: I have a craftman 42 in dual blade riding mower.
Either the deck is uneven or one of the blades are upside down
Posted on Apr 24, 2009
wireguy212
  • 1627 Answers
SOURCE: The deck blades stop turning in reverse unless switch is pulled.
This is a safety feature that is not that hard to do so i say live with it.You do'nt have to hold it up just pull it up before you start backing up and once your moveing you can let go without it shutting off the deck until the pedel returns to neutral again,all tractor have it by law after a certain date so jumping around it is niot a good idea.
Posted on Dec 02, 2009
  • 9 Answers
SOURCE: cutting blades won't disengage
Check you blades to see if one is bent. Do this with the mower NOT RUNNING and the KEY OUT of THE IGNITION! Look under the deck to see if one is bent. This will cause the wobble. As far as no disengaging your electric clutch could be bad. The bearing could have seized up.
Posted on Apr 25, 2010
  • 3 Answers
SOURCE: Mower will not disengage
this is because your belt that drives the blades is to tight i suggest getting a looser belt
Posted on May 10, 2010
My new 10.5 HP 30in. Troybilt riding mower just quit running after trying to go in reverse and forgetting to disengage blades.Cannot get it restarted for anything. Help?
One or more safety switches are not working. Engine off, put it in neutral, disengage the blades. Now sit on it, and try to start it. If that doesn't start the engine then take a multi meter and check for continuity on all the switch locations.
Mar 15, 2017 | HP Garden
Hi...I have a 2005 Cub Cadet 2042. With the switch in ''normal'' and the PTO engaged, when going forward cutting the grass the PTO will disengage for no apparent reason. You have to push the PTO knob in...
In the cub cadet, the PTO power is maintained via a latching circuit that includes a reverse switch and a reverse relay. Locate the reverse switch that senses whether the tractor is in reverse -- either it's come loose, become misadjusted, or it's failed, or the wiring and connections are loose. You could bypass the switch to confirm this as the problem.
Jul 10, 2010 | Cub Cadet Garden
Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades run in reverse and only for a short distance going forward
ok when was the last time you had the hydrolic fluid changed ?
or the oil for that mater ?
oil breaks down
you wouldnt cook your french fries in year old oil but you will cook your tranny with it in a cub or mtd machine 100-120 hours max for the fluids in an mtd b4 they start to loose texture or viscosity ( sound it out)
hydro pumps di die mtd has 1 monster that is quite expensive also have you changed the filter on the rear axcel lately or is it full of nut butter and in bypass mode
100 hours doesnt seam like much but for a tractor it is
service service service
Jul 25, 2009 | Garden
When I engage the mower blades, the tractor tries to stall
Hi..my name is Keith..and the newer mowers have all kinds of safety switches..and the mowers will shut off..if you put the mower in reverse with the blades on..so i would suspect you have a bad reverse safety switch..i hope this will help..if not please write me back
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
283 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
