Question about Electrical Supplies
What type of oil do i use for my Honda ES7500 generator?
3 Suggested Answers
  • 154 Answers
SOURCE: Honda EM 2500. What oil does it require and does
30 weight
Posted on Jun 14, 2009
caroldon
  • 17129 Answers
SOURCE: honda petrol em70 ..is... generator what type oil is required for this generator please
You can use Engine Oil of API - SF grade 20W40 & 15W40.
Posted on Nov 21, 2011
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
My honda 2000 generator only runs for about 3 seconds then shuts off
Its sure that its missing oil at the engine.Modern engines have a oil alert dispositive. Check oil level,if it is low,just fill with more oil at carter engine.
Sep 03, 2014 | Honda EU2000IKN EU 2000 Watt Generator 50...
Honda 5000 generator with remote starter running rough.. tis like ******* or something.. oil was almost empty so i stopped generator and added oil and restarted.. can u give some advice as to how to remedy...
Those generators are set up with a low oil saftey but your gonna want to check compression anyways just to verify it is where it needs to be. Im gonna guess its to be between 120-160 psi, check your manual for the service limits. after that check your air filter, valve lash, fuel filter etc etc.
Mar 29, 2012 | Honda Mmd 5000 Watt Electric Start...
Honda 5000 generator clear oil out leaking thru air intake
There is supposed some oil in there. There is a tube to the carb intake that allows flow like a pcv valve
Oct 05, 2010 | Honda Mmd 5000 Watt Electric Start...
Honda 3000 eu no spark replace ing coil still no spark
Is there enough oil in the crankcase? Many generator ignition problems come from the oil level sensor. Either not enough oil or the sensor being bad.
Jul 21, 2010 | Honda 3000 Watt Portable Generator
How can I shut my Honda eu1000i off from inside the cabin?
You should not have to cut any wires to install a remote kill switch. Most honda engines have an oil alert what will cut ignition if oil level is low. The switch actually shorts the itnition to ground just like the on / kill switch. Just unplug oil alert wire from harness and add a homemade connector with second lead and connect another wire to ground/frame of generator engine. When you short these two wires together it should kill engine. Solder these two wires to a female connector (Radio Shack) and just leave inside generator when you want remote switch. Attach switch to leads of desired length of male connector to mate with female connector at generator. Good Luck.
Jul 10, 2010 | Honda Electrical Supplies
How do you check the oil level in the 7.5 kw marine generator? There is no dip stick.
GENERATORS DO NOT HAVE OIL IN THEM THE MOTOR ATTATCHED TO IT DOES WHAT TYPE OF ENGINE,? IF ITS A HONDA THE OIL LEVEL IS THE BOTTOM LIP ON THE BUNG AT THE BASE OF THE ENGINE
Sep 21, 2009 | Electrical Supplies
Honda 5.5 generator gas is filling oil compartment when not in us
turn the fuel off when not in use,it is going through the carb.to the oil.
Mar 17, 2009 | Honda 3000 Watt Portable Generator
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
