Question about Bose Audio Players & Recorders
Auxiliary jack is broken and stuck in the bose sounddock?
SOURCE: No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Posted on Nov 24, 2009
SOURCE: docking cradle in bose sounddock
Order Prod Number 041615 , Description: "279103-004 MOD ASSY CRADLE BLK SOUNDDOCK" from Bose spares. Costs £35. Undo the four philips screws in base, romove cover and replace whole cradle assembly. There is a circuit board attached to the main unit by a ribbon cable - you do not need to remove this cable you can instead can thread the circuit board through the old cradle. Then pull out the ribbon cable that connects the new assembly to the circuit board. Installation of new one n reverse. Protect from static by using wrist strap etc.
Posted on Dec 03, 2009
  • 51 Answers
SOURCE: I need the Bose SoundDock schematics
No, but I have repaired many without a schematic. Aside from damage, there are abiot four basic failure modes. Tony
Posted on Feb 22, 2010
SOURCE: Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Posted on Mar 10, 2010
  • 51 Answers
SOURCE: Bose Sounddock failure
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original. Try the PSUif you can. The click is the PSU shorted that can be caused by a fault n the sound processor. Invebo will repair it for you too.
Posted on Aug 16, 2010
Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Jul 11, 2010 | Bose SoundDock Portable Digital Music...
Bose sounddock seriesII remote will not navigate playlist
EIther the remote is faulty or a broken comms pin on docking connector. www.invebo.com will rpelace the dock connector for you for about 30 Euros.
Apr 16, 2010 | Apple Bose SoundDock Series II Digital...
I need 282490-001 part for my BOSE docking sound station.
go to Bose Center Service in your city, and they change the part. I changed today and cost is usd 85 everything.
Nov 17, 2009 | Bose SoundDock Portable Digital Music...
Sep 22, 2009 | Bose SoundDock® (Black) Docking Station...
Missing power back bose series1 sounddock
If i'm not mistaken you can find those on Bizrate.com.
Sep 04, 2009 | Bose SoundDock Digital Music System for...
Bose sound dock doesn't work at all
If this is the original SoundDock, the power supply in back is 4 pronged and a pin could be broken. If it makes a quiet thumping sound, then just make sure the power supply is not plugged in upside down (it's easy enough to do).
If this is the SoundDock II or the SoundDock portable, it's hard to say why this would happen, so you should call Bose on that one. There should be an indicator light that tells you when it has power..
Jun 19, 2009 | Bose SoundDock iPod Digital Music system...
BOSE SOUNDOCK CONNECTRO BROKE
You can't - the repair needs to be done centrally as the company would be at risk if it sold electrical parts to people who aren't qualified to repair such items. Therefore you need to call Bose and have this repaired, however it's quite a common fault so shouldn't cost too much.
Dec 15, 2008 | Bose SoundDock Digital Music System for...
131 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
