Question about Whirlpool LGV4634JQ Gas Dryer
Runs, but no heat
Dryer has not been used in about a year. It was working fine before.
  • 198 Answers
First of all if you have fuses check for one of the fuses being open, if circuit breakers be sure they are ok. Next check for 240 volts to the heating element, if you have that and no heat replace the heater
Posted on Jan 07, 2009
Dryer has quit heating
Sounds like the heat coil has went bad you can pick one up at a appliance store,but the cost would be close to buying a used dryer,also check and see if something has gotten on the coil and shorted it out I had a dyer one time that I found a little dead snake on it,I removed it and it work for many years good luck....
Jan 10, 2013 | Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Maytag Gas Dryer. Gas on. Ignighter kicks on. no heat aftrer running along time. Set idle and retried with no heat... Has ran fine for years... gas source has not been off for years... thanks
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101ooo
Aug 18, 2011 | Dryers
It's running fine but not heating at all on any
heatman101--==-
Aug 04, 2011 | Whirlpool Dryers
I have a maytag neptune which is about five years old. It runs fine, but the dryer does not heat up. What should I do orcheck to diagnose problem?
heatman101
Jul 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is not heating. Seeems to be running fine except every few minutes makes a churning type noise and there is no heat. We cleaned the lint trap and the exhaust hose. Is this an expensive repair?...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 30, 2010 | Frigidaire GLGQ332A Gas Dryer
My Frigidaire dryer has no heat. It was working fine last week and I could look inside and see it was ''red'' around where it was heating from the back part. 1 day later, no heat & no ''red'' ring in...
Check your breaker box. Dryer will run on 120 volts but will not heat without a full 240 volts. If that's not your problem, it's best to hire someone. I only say that because this brand of dryer is not easy to work on.
Nov 16, 2009 | Frigidaire FEQ332E Electric Dryer
No heat
While your model number is not listed on the Service Manual at the link below, you will find information on how to check out the heater on page 8-6.
Good luck
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Sep 29, 2009 | Maytag MDE16CS Electric Dryer
Will not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jul 16, 2009 | LG DLE7177 Dryer
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
