Question about Dishwashers
Hover dishwasher hnd325 not emptying water when cycle finishes
    Director Badge:
    Uploaded 100 video answers.
  • 87 Answers
If its stopping with cold water in it then it's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Posted on Jun 29, 2016
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
SOURCE: Dishwasher--water in bottom -end of cycle.
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Posted on Feb 26, 2008
rickzilla
  • 706 Answers
SOURCE: LG LD-14AW3 Dishwasher leaking after cycle
Sounds like you've diagnosed the solution on your own.. Most of the inlet valves are spring loaded so that if power is removed or disabled.. it defaults to a closed state and doesn't allow water int the wash basin. To open, they need to be energized by the control system so you may have one of two issues.. a faulty inlet valve that doesn't spring closed when it is not energized or a controller that is comanding that valve to open ( less likely of the two) For a quick test.. make sure the DW is dry inside and open the door. wait and watch for water to enter the basin.. If it does begin to fill up.. your inlet valve could be the root of your problem.. It is also possible that you are back-siphoning waste water in from the drain system. If the water looks dirty then that is more than likely the problem so you may have a clogged pump, kinked drain hose or your drain system itself is not draining as fast as the DW pump forces the water out.
You should routinely clean the pump filter so that the pump can remove all the wash water without having to draw it thru food debris caught in the filter.. Hope someof these ideas will help you solve your problem..
Posted on Sep 01, 2008
  • 116 Answers
SOURCE: Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Posted on Sep 17, 2008
  • 11 Answers
SOURCE: water left standing inside the buttom of dishwasher
It depends on What kind of Dishwasher you have. If the pump is old it may very well be bad or it could be a drain hose routing issue. The drain hoseshould always be looped up in the cabinet under the sink. If the drain hose is laid down low, the water could be backing up from the hose back into the dishwasher.
Posted on Feb 07, 2009
Hoover hnd325
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Aug 04, 2013 | Dishwashers
Water not emptying
check if the dishwasher is level. designed to drain correctly under level conditions.
Apr 21, 2012 | Bosch Dishwashers
The dishwasher cycles down to 1min and then keeps trying to empty. It never does get there though. Water is still in the sump. Emptied this out once and it started ok again. Removed side cleaned out the...
This answer may be of no help but we had a similar problem a while ago and the problem was a small piece of chop bone caught in the pump, this prevented it compleatly finishing the cycle. Water was always in the bottom of the washer.
Nov 08, 2017 | Neff 24 in. S5457X0GB Built-in Dishwasher
Our integrated dishwasher takes on water but the tablet does not disolve. The dishes are not clean after the cycle but they are hot.The water empties.
Buy a Finish diswasher cleaning kit from the supermarket and run the dishwasher with it. Follow the instructions on the label of the kit. Use one of the long wash cycles on the dishwasher so that temperature reaches above 60deg C.
Also provide the make and model number of the dishwasher.
Dec 10, 2010 | Dishwashers
My Dishwasher has a rapid flashing light
I get the same problem with a pepeating beep warning. Only solution I've found is to switch it off using off button then switch it back on. It waits a few seconds then finishes the program and drains. The dishes still seem to be quite damp after. Hope this helps
Jul 12, 2010 | Hoover Dishwashers
Drain pump running when unit starts but no water to appliance
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Jul 05, 2010 | Bosch SHU5315UC Dishwasher
Hotpoint ultima df32 dishwasher
I have had this problem with a dishwasher before it was the pump. some of the water was empting but that was the weight of the water pushing it down! if its still under garentee get someone out, I dont know how expensive pumps are! it may be easier to look on ebay fot a new one!
Mar 29, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
