Reset hightemp limit switch on a trane xr80 furnace
2 Suggested Answers
  • 1015 Answers
SOURCE: Trane XR80 blows cold air.
I know that it's easy to spend someone elses money but in my experience when you get one actig that erratic it's usually the control board. I would check all the wiring including thermostat. You never know you might get lucky. I hope this helps you. Thanks
Posted on Nov 29, 2010
Trane XB80, no heating, limit circuit open
Sometimes these can be reset by gently taping them on the floor. Can be caused by not changing your furnace filter.
May 18, 2014 | Trane American Standard Trane American...
Hi :) I have the Trane Furnace that just turn on
on older tranes if 120v power is reversed it would do that try switching leads on pigtail to board. make sure to unplug first!
Oct 31, 2013 | American Standard Trane Ge Gas Furnace...
Trane XR80 Furnace won't stay running
It sounds like your flue work in your main problem get this fixed first then see how it runs , pipes should run all the way out of the chimney .
Jan 23, 2013 | Heating & Cooling
Reeeeeeeeeeeeeeeeeeeeeeeeee
  • Hey, nofarmark91
    Turn the Coleman furnace system switch to the "Off" position on the electric service panel.
  • Locate the manual reset switch near the left side of your furnace blower. Your Coleman furnace has an upper limit switch for manual reset and a lower limit switch for automatic reset.
  • Press the reset button, which you will find in the middle of the limit switch. Use this manual reset button when the furnace burner will not operate. (See Reference 1 pg 4 "The Furnace Controls and their Function/Important" & Reference 4 # 3)
  • Turn the system switch to the "On" position.
  • Good Luck
    Jul 29, 2012 | Coleman Heating & Cooling
    Trane XR80 blows cold air. Inducer motor comes on, glow bar glows for few seconds than goes out and inducer motor shuts off. Immidiatly after the main blower comes on and blows cold air. Will blow until...
    Nov 29, 2010 | Heating & Cooling
    I have a trane xb80 furnace and the red light flashes 5 times what is the problem?
    On the back of the door panel or in the manual if you have one, the codes for the flashing lights should be there.5 flashes should be a code for one of the limit switches being tripped.I assume your furnace isn't running. I do not Know what 5 flashes is on a trane unit,but if you find the code chart,should be inside the door panel and replie I can help you. Doug
    Nov 27, 2010 | Heating & Cooling
    When turning on heat after a period of using air
    It sounds like the fan limiter switch is going bad. This switch waits until the air temp is high enough for heating the house before allowing the fan/blower to come on. There is another switch that shuts off the blower when the air drops to a certain temp, or it may be the same switch that does both jobs. Hope this helps.
    May 09, 2010 | Omega Trane Furnace Draft Inducer Blower...
    Have an older Trane furnace. no 'board' just
    If you do not have a fan board you have a fan limit switch. That brings the fan on about 120 and off at 90. It is located in the middle of your heat exchanger. Check across with voltmeter when you turn it on. If you have voltage after it runs for a while its bad. Or just jumper across it and see if afan comes on. They just go bad. Pick one up at HVAC supply house or you can order on line. If you have an electronic thermostat. On the back it has a switch that says gas or el switch to electric and the fan will come on with furnace. Rus but you still need to change fan limit this will just get you thru till you get it.
    Nov 28, 2009 | Ruud Central System Air Conditioner
    INSTALLING A GAS STOVE
    you would need to get a LICENSED plumber for the installation of gas line. did i mention LICENSED??? its your house dont mess with a guy that tell you he's done some plumbling before
    Mar 16, 2008 | Kitchen Ranges
    Heating & Cooling Logo
    336 people viewed this question
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
