Question about Oster 6307 / 6309 2-Slice Toaster
Oster toaster outer heat elements will not work: How fix?
Oster 2-slice toaster will toast with only the two center heater elements actually heating. The outer two heater elements do not work. I have metered the outer elements & there is power to them but no heating. How do I fix this problem?
2 Suggested Answers
HansPP
  • 2510 Answers
SOURCE: the innerside elements of the
You need to take the sides off and try inspect the inner element, looking for a break in the flat wire, or a bad connection where there is an eyelet or such in the mica where the leads connect to the element. You will probably have to buy a new center element from an electrical repair outlet and replace it.
Posted on Jan 30, 2011
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Toastmaster B1042 toasts only one side of one slice and both sides of other slice
The is by design. The bagel side only heats on one side because of the bagel not needing to be toasted .
Jan 16, 2013 | Toastmaster Kitchen Appliances - Others
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
The innerside elements of the toaster are not warming up. Only the outer sides of the bread slices are toasting. How to fix?
Jan 30, 2011 | Oster Kitchen Appliances - Others
Our 4-slice toaster (model 4cbc) is only toasting part of one side of the toast, as if a heating element has burned out.
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Aug 05, 2009 | Dualit Kitchen Appliances - Others
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
Black and /decker toaster model T3550. The outside elements work but the middle ones do not. so only one side of the bread is toaster.And the handle must be held down the whole time to toast
The heating element wire is really thin and there is a great posssibilty of breakage. There is also a spring switch in which the lever locks when toasting. needs replacement.
May 11, 2009 | Black & Decker Toast-It-All Plus T3550...
One side not working
Sounds like the element has failed. Not much you can do as even though they cost more than a 2 slice, parts availability is slim and none.
Jan 28, 2009 | Waring WCT810 4-Slice Toaster
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Oster 6307 / 6309 2-Slice Toaster Logo
49 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
