Question about ECHO, Inc. PB-251C Handheld Blower
My echo leaf blower pb6000 started flooding out , rebuilt the carb no change should I just buy new carb
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 603 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
SOURCE: Need to replace fuel filter
Fuel filter is located inside the fuel tank. You have to make a hook out of about 10" of stiff wire (wire coat hanger works perfect) Hook end should be about 1/2" wide. Remove the fuel cap, insert the wire hook and snag the fuel supply tube with the filter attached to the end. Pull it back through the fuel filler opening, replace the filter and reinsert.
Posted on Apr 15, 2009
  • 148 Answers
SOURCE: Echo leaf blower is bogging down at full throttle,
Have you tried cleaning the carb?
Posted on Aug 24, 2009
Testimonial: "Thanks for the suggestion, that sounds like what it may be. "
  • 4340 Answers
SOURCE: I have a 2 stroke engineer leaf blower that will
Paul, fix the old carb. They can gum up and sometimes need to soak (disassembled and soft parts removed, like the float, gaskets and inlet valve.)in carb cleaner and then be blown out with compressed air.
Posted on Nov 06, 2010
Stihl blower wouldn start, rebuilt carb it floods terribly. good compression. what did I screw up in the rebuild? I have rebuilt many carbs and they worked.
you have screwed up on the needle and seat assembly( probably dirt under the needle )
that is why it is flooding
as for the rest have you put the diaphragm on the correct side of the gasket
Jun 11, 2016 | Stihl Garden
Purge bulb not working on echo pb-500t,gas leaf blower
get a new primer bulb and diaghram and rebuild your carb or buy a new carb,same price,gas and ethanol and oil kill carbs, echo A021000781
Echo PB 230LN 05001001 05020818 Handheld Parts
May 26, 2015 | Echo Garden
Why does my blower floor out to kiwk
adjust need and seat or make sure needld a seat or seated right soundes like not should be no need to adjust needel sounds like put in wrong flip it over metal side go on needle
Aug 06, 2014 | Echo Power Blower PB-500T
I have a riobi leaf blower. it will not start. i have changed the gas,gas filter, spark plug and rebuilt the carb. it still does not start. i took the muffler off to check the screen. it was full of gas....
The screen was full of gas? Or was that the intake filter? If the carb is moving this much fuel then I would check for spark. You said you replaced the plug but maybe it is the ignition module that is bad. You dumped the fuel first which is the best thing! Try starting with the intake filter off as well. See if the carb is spitting back out the intake. This is a sign the carb may have a checkvalve stuck open. Which will flood it like crazy and prevent starting as it fouls the spark plug. Also....you can dump all the fuel and just put enough in to make it sputter and see if that works. Then you know you have a carb issue without flooding it. Be safe and good luck!
Jul 09, 2014 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Starts dies
Fuel lines could be collapsing from being soft, mush from ethanol in gas, possibly you have wrong carb kit, or something put together wrong, fuel lines reversed, double check everything then make sure you exhaust screen is not plugged, cause this will do same thing.
May 24, 2013 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Echo pb251h. Blower will only stay running if i pump primer knob. Carb was rebuilt, changed fuel filter, checked exhaust port, insulater appears to be ok, compression test around 100psi,new fuel lines and...
when the carb was "rebuilt" Did you pull out the screen and clean it out and also did you pull needle and diaphragm out and clean it out good, because if the needle is not working or the neoprene tip is swollen your needle adjustment will be out of whack,sometimes carb cleaner will make it swell up to where it won't open enough to get fuel through it....suggest you replace the needle and adjust your height of the tab to flush with the body of carb and make sure you have a good diaphragm in it along with new check-valve diaphragm, then make sure your primer is hooked up right ..it should be pulling fuel through the filter to carb and through carb and back to tank,your problem is definitely in the fuel system, keep trying different things you will figure it out
May 26, 2011 | ECHO, Inc. PB-251C Handheld Blower
I have a 2 stroke engineer leaf blower that will not start. I have spark and using starter fluid gets it going but it quits. I know I have gas getting into the carb. - I think problem is probably in...
Nov 06, 2010 | ECHO, Inc. PB-251C Handheld Blower
INSTALLED NEW CARBURETOR NOW WILL NOT START?
Assuming all gaskets and lines were installed properly, try priming it with a little gas directly into carb, or remove spark plug and put a little gas directly in cylinder and see if it picks it up. Sometimes for first start this is necessary.
Oct 05, 2010 | Echo Back Pack Blower Pipe Kit Pb4600...
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
ECHO, Inc. PB-251C Handheld Blower Logo
47 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
