Question about Vivitar ViviCam Cameras
T325 camera not charging
Doesnt charge up fully
SOURCE: logitech pocket digital camera
Same happening to me. The solution is to try it in a different USB port, as it is a USB related issue.
Posted on Jul 21, 2008
darntoothysa
  • 489 Answers
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD600 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Posted on Nov 11, 2008
IrishDruid
  • 2712 Answers
SOURCE: I have a samsung L200
You may have to replace the rechargeable lithium ion battery. (Even rechargeable batteries have a life-span :)
Posted on Dec 03, 2008
SOURCE: My battery is fully charged, camera goes on and shuts off.
this generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
Posted on Jul 15, 2009
  • 43 Answers
SOURCE: MY DIGITAL CAMERA KEEPS SAYING
Remove the battery and push the reset switch for about 5 seconds. Reinsert the battery.
Posted on Jan 29, 2010
Sony Optical Zoom Steady Shot DSC-W530 wont turn on
Try another fully charged battery first of all. It might be a poor or damaged connection.
If another battery doesnt work, then its the camera.
If the camera doesnt come on the mother board is damaged. You will have to have the manufacturer change it out. Might be expensive
Mar 05, 2014 | Sony Cameras
Doesnt turn on
Are you sure the battery is fully charged? are you sure you did remove the USB cable?
When your camera is still connected to a charger or computer you can't switch it on.
And even fairly new batteries, can stop working.
Try to charge the battery several times, but if after a few attempts nothing changes, I think you need a new battery.
Jan 23, 2014 | Nikon Coolpix S3300
Instruction manual for vivicam t325 to download
i need to download the soft wear for a vivcam t325 i have the disk but my laptop dont have a cd drive ..... Please can some one direc me to where i can download it please
May 04, 2012 | Vivitar Cameras
Samsung sl605 wont turn on
A charging battery's light is red. If it turns green then it means it is fully charged. Since you had stored your battery for a while, try to charge it by using a battery charger to kickstart it. It should work. Whatever transpires let me know. thanks and rate this answer.
Dec 24, 2011 | Samsung SL605 Digital Camera
Flash doesnt operate on any flash mode
Follow the steps below to check if the issue can be resolved.
Check if the battey is fully charged.
Charge the battery in the Camera and check if the flash charge lamp is flashing. Once the Lamp goes out the Flash in the Camera gets charged.
Once it is charged, press the Up Arrow button in the Camera continuously to select the Forced Flash which will strobe regardless of the surrounding brightness.
Make sure that the Camera is not in TWILIGHT or LANDSCAPE scene selection mode.
Make sure that the MODE and REC MODE is not set to BURST3 or BRKTG from the Menu settings.
Change the REC MODE and SCENE SELECTION Mode to enable the Flash in the Camera.
If the issue persists, service may be required.
Thanks for using Fixya Support.
We wish you a happy Christmas and New Year!!!
Dec 23, 2010 | Sony Cyber-Shot DSC-S85 Digital Camera
I own a Sony DCR-HC47E Handycam.It will not turn on
i have a problem with my sony dcr-sr47 camcorder it wont charge the battery camera works fine with power supply any solutions.
Dec 15, 2009 | Sony DCR-SR47 Camcorder
The battery does not charge on the charger. the light keeps on flashing but doesnt charge.
this is the fix:
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps.:
Jun 23, 2008 | Casio EXILIM Card EX-S770 Digital Camera
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
27 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
