I have a goodman aruf364216BA I am trying to wire to a Robert Shaw 6220 programmable thermostat and the ac will not work
  • 182 Answers
SOURCE: Goodman Furnace/AC unit not working
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Posted on Jul 04, 2008
  • 8 Answers
SOURCE: Wiring Hunter Thermostat to 6 wire Carrier fa4bnf036
you probably purchased a 4 wire thermostat which we call heat/cool you stated you have 6 wires which signifies a heat pump you have to purcahase a heat pump thermostat and then write down the color of the wires to there related spots example...yellowe-y red-r white- w and so forth also before you do this kill the power the voltage typical for residential is only 24v's but if the wires touch you could blow a fuse
Posted on Dec 15, 2008
  • 4 Answers
SOURCE: replacing old thermostat with new digital
Wire nut or tape the black off. The red is normally 24volt supply power to the t-stat. Blue may or may not be the common. Have a voltmeter?
Posted on Jun 24, 2009
daddyo742001
  • 70 Answers
SOURCE: Hunter 44110 programmable thermostat not turning off ac
You may and an anolog stat and the old one was digital if so it won't work. Digital sends info to system anolog is just a set of points open or closed. Digital can carry tons of info to system like a computer. Like comparing a computer to a rock. Sorry but you need to go back to proper type stat.
Posted on Jun 30, 2009
  • 26 Answers
SOURCE: I have a goodman furnace and ac unit the fan and
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Posted on Jul 07, 2009
Robert Shaw 9620, replaced batteries. still shows lo batt. checked batteries are good. no other display but low battery
It sounds like the board is locked up. Try this...Take the battery out. Now, take off the red wire (or the one marked "+")
Wait 30 seconds. Reconnect the + Wire and then reinstall the battery.
Sometimes surges can lock up the board. The battery, by the way, doesn't do anything unless the power goes out, so they can last for years.
Jan 09, 2011 | Shaw Robert RS-9420 Thermostat
T stat shows -AC why?
Perhaps it's running on the battery back-up and is telling you that the AC isn't on to the unit.
See if the wires broke off the screw terminals. It'll have to be the + OR the - in the board.
It's not THAT unusual since the wires are thin and get nicked when trimmed for installation.
Dec 30, 2010 | Shaw Robert RS-9420 Thermostat
I cannot get robert shaw theromostat to reset its a 9420 model. I have reset and it goes down in temperature to 45 f degrees i also shut off the circuit breaker. do you think it needs to be replaced. I...
If you are even reasonably good with a screwdriver, you should be able to replace it yourself.
Turn off the breaker, pop off the cover and take off one wire at a time and put it in the exact place it came from onto your new one.
eBay has new RS thermostats for $30 non-programmable.
$60 programmable.
For $280 I'd be willing to try it myself 4X and still save $40.
Sep 19, 2017 | Shaw Robert RS-9420 Thermostat
Our Robert Shaw thermostat 9520 just went blank. Do you have any ideas, nothing is working?
Try replacing the batteries.
Remove the cover by using a coin or screwdriver to prise it off. Insert the coin at the left side between the backing plate and the the cover, and twist.
Romove old batteries and insert new ones.
Mar 06, 2010 | Shaw Robert RS-9420 Thermostat
Error code on robert shaw 9600 thermostat
i am having a ER on my shaw robert theromostat model RS-9420
Jun 30, 2009 | Shaw Robert RS-9420 Thermostat
Can not get the heat to work only cold air
Two questions what brand heater and what are the wire colors at the t-stat
Jan 04, 2009 | Hunter Fan Company 5/1/1 Programmable...
Honeywell 6300 programable thermostat instalation
The thermostat is a low voltage circuit (24 volts) most of the newer heating systems have a fuse for the low voltage controls. If you are having to re-set the high voltage circuit breaker, then you have something else wrong. When does the breaker trip? while its running or after it shuts off?
Nov 18, 2007 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
