Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I don't know where to look for a Glass Cooktop Replacement
I cracked the ceramic glass coot-top of my Frigidaire Self-Cleaning freestanding oven.
Where would I find a replacement?
How much does one usually go for?
  • Kyle Fair Jan 08, 2009
    The model number is: PFEF375JFS
What is your model number and I can look up the part and tell you what they cost so you can call some appliance stores for comparison
Posted on Jan 04, 2009
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Glass inside oven is broken and needs repair
Here is a tip that will help you with that...
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Apr 21, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I used the self cleaning feature on my stove and began to clean with a wet cloth before it was cool and the glass cracked on the door. is this able to be replaced?
yes the glass can be purchased separetly call your local part store give them the model number and they can get you the right part
Mar 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire self cleaning oven model # 316255347. The top cera mic eyes come on for just a few seconds then off.All 4 eyes do this.You can turn the tempature up a little and they come back on but go off in...
absolutely nothing, they are cycling properly to keep the glass top hot
you are not cooking wioth the heat of the element,
but with the heat the glass absorbs from the element
if they are all doing it,,,, it is normal trust me
i have handled this call about 500 times since glass tops first hit the market
Oct 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire glass top range
yes u can.unplug the unit from power.remove the screws under neath the glass top at the from and lift the top up,hold it up using a piece of stick like u hold bonnet of car.then u can see all the elemnt and they are pretty straigtfoward to chg.
Aug 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Need to replace glass top on a frigidaire eletric stove. model# FEF336BGDD serial # VF01609618 where can i find this item?
Were you able to find a replacement part? I have the same problem, and am having difficulty finding a replacement.
Jun 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Glass top broke, can it be fixed
They do sell replacement glass for these, you will have to contact the manufacturer to order or find where to order.
Mar 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Glass cracked on smooth top stove would like to know if I can replace it myself model #FEF366DSB Frigidaire
Usually short instructions come with the glass. Just be careful about the wires not to pinch them tween the new glass and the frame. Use the type sealant they recommend.
Mar 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
315 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
