Question about RCA HD61LPW164 61" Rear Projection HDTV
No vidio audio ok
Replace lamp still no vidio, the lamp will not turn on. i try the lamp on onother tv, lamp is good. haven't try the old lamp but i have a felling it's still good
    Novelist:
  • 192 Answers
Normally the symptom, audio/no video is the DMD. The light needs to be changed. Contact RCA at 866-465-7157 for a servicer in your area.
Posted on Jun 03, 2007
I have a 10 year old JCV TV that the backlight is not working, is it worth trying to repair?
You haven't given the exact model number to your TV here. Back light inverter might also replaced along with defective CCFL lamp/s. It wont cost more. Anyway will cost around 10% of the total cost of the TV
Aug 16, 2012 | JVC Televison & Video
I have a Fijitsu 50 inch plasma tv. I installed it on the wall, hooked up a speaker. I get sound on one cable channel with no video or I switch to another channel and get video without audio. I cannot...
OK ~ try this... Connect a makeshift antenna to your Antenna proper connection/connector.
Almost anything somewhat large, flat and is metal should work OK... Even a length of old lamp cord may work too! Hopefully you are in range of at least ONE standard HDTV DIGITAL broadcast transmitter(s) "over the air".
IF your audio is now OK suspect that CABLE BOX!
And how about your DVD player? Is your audio and video good using it?
Anthony
Jan 29, 2018 | Fujitsu 50 in. Plasma TV
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
Gradually lost picture; Mitsubishi VS-50501A
you need to buy a new lamp and replace the old one thats your only problem its about $200 for the lamp
Mar 27, 2009 | Mitsubishi VS-50501 50" Rear Projection...
TV on/off
How long is your TV on before it turns off? Check the fans and make sure they are all working. The TV may be shutting off due to overheating if a fan quit working.
If you think the lamp is still good maybe try replacing the lamp ballast.
Jan 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
It doesn't work on my laptop Vista Home addition
I think the problem is windows vista itself. This MSI product does not have drivers for vista...
You can try forcing the xp drivers, but it oriblably won't work.
Good luck
Oct 15, 2008 | MSI USB 2.0 TV Tuner (MSIVOX2)
Have to re-set everytime to work
Cause it's the official tv of nascar and the nfl and most other really expensive advertising. As a servicer and an owner of the same set, I first would try to vacuum out all vent holes behind set. This has caused mine to shutdown several times. I don't completely understand you about modes, but make sure all audio/video cables are connected well and hdmi cable. Also, make sure that the door switch on the lamp cover is fully engaged. They had an intermittant problem with some of them not making good contact. Go over your power strips and/or extension cables real good and hope for the best. Good luck.
Jun 12, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Tv wont come on
Good Day,
If you use your TV a lot then you need to replace the lamp, but if you only use your TV about 8 hour a day, then you also may need to replace the ballast.
The lamp is really easy to change. You should get at least 5,000 hours on your lamp.
Call RCA customer service and ask for a concession to replace the lamp and ballast. This is a common problem for RCA!
Good luck, God Bless.
Jun 11, 2008 | RCA Televison & Video
Need to watch recording on tv
If your camera has audio vidio cable (just get a cheap one which has a yellow, red and white connector) connectors. simply plug them in the audio vidio out on camera and audio vidio in on TV and thats it.
Let me know what type of connectors you have on your camera?
THanks
Dec 07, 2007 | Sony Handycam CCD-TRV107E Camcorder
Lg tv and parcific vidio
YES, DOES YOU PACIFIC VIDEO HAVE COMPONENT , COMPOSITE OR HDMI OUTPUTS ON THE BACK ? THE HDMI HAS BOTH AUDIO AND VIDEO SIGNALS AND IS THE BEST QUALITY PICTURE. BUY THE CABL AT RADIO SHACK, WALMART ETC.
COMPOSITE IS THE YELLOW RCA CONNECTOR FOR VIDEO AND RED AND WHITE RCA CONNECTORS FOR LEFT AND RIGHT AUDIO.COMPONENT IS THE RED, BLUE AND GREEN RCA CONECTORS AND RED AND WHITE FOR AUDIO L & R.
Nov 24, 2006 | LG TU-60PY2DR 60 in. TV/DVR Combo
RCA HD61LPW164 61" Rear Projection HDTV Logo
85 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
